Performance Tool OBDii - Should It Work?
Old Mar 31, 2021 | 10:17 AM
04Xjrsteve's Avatar
Default Performance Tool OBDii - Should It Work?
Would like to read the codes on my 04 XJR. Performance Tool sells a code reader that looks simple to use. Has anyone had experience with this one? Did it work? It is very inexpensive.
Old Mar 31, 2021 | 04:17 PM
jackra_1's Avatar
My guess is that it will only read generic codes and not Jaguar specific.No matter how cheap something is if it does not do the job its waaay too expensive.
Old Mar 31, 2021 | 04:18 PM
jackra_1's Avatar
So much info in here on OBDll scanners/tools
Old Mar 31, 2021 | 04:53 PM
04Xjrsteve's Avatar
Thanks, Jack. I tried reading some of the other threads & candidly, was not left with a sense of confidence. The one mentioned above is the one that a local parts house uses to give a "free" read.
Since I would read the codes so seldomly, I'm inclined to pay the dealer $150.00 per read. However, since we're in one of the more opulent places in the world, the dealer is so busy, I almost get into an accident in the parking lot every time I go there!
If I buy, I would like one that is easy to use & can read & clear codes. Anything more sophisticated than that will likely be wasted on me.
Old Mar 31, 2021 | 05:06 PM
jackra_1's Avatar
The iCarsoft i930 is what I use. There is a newer model available now I believe.
Its easy to use unlike the jlr sdd software that I also have which I use for programming when needed.
Can not do that with the iCarsoft however it will do what you want including resetting fault codes.
Old Mar 31, 2021 | 09:04 PM
Panelhead's Avatar
Been using the i930 for several years. I tried a clone with old factory software, Mongoose, and old computer. So clunky it never did as much as the iCarsoft.
Watched a factory tech code a key with new Jag computer and software. Still clunky. Super slow.
Old Mar 31, 2021 | 10:27 PM
04Xjrsteve's Avatar
Thanks again, Jack & thanks, Panelhead.
I believe this is the one you recommend:
Amazon Amazon
This one also looks good:
Amazon Amazon
Old Mar 31, 2021 | 10:55 PM
Panelhead's Avatar
We have the first one. The second one is reported as having more functions. Fuel trims is nice to have.
Old Apr 1, 2021 | 09:00 AM
jackra_1's Avatar
For simple diagnostics the iCarsoft is way better than JLR SDD however IF you need to do actual programming then the iCarsoft just does not cut it.
JLR SDD is difficult to use, but not slow on the right laptop set up, and has saved me $1,000s over my sold Jaguar XJR and my Range Rover.
Old Apr 1, 2021 | 09:49 AM
Panelhead's Avatar
Default Slow is relative
Watched a senior Jaguar tech spend 45 minutes typing and waiting to code a key. Not a smart key either. His rig seemed better than my clone. But still seemed outdated.
Maybe the new owners have invested in software.
Old Apr 2, 2021 | 03:09 AM
paydase's Avatar
IDS-SDD is not very user-friendly.
And a VCM looks big and outdated compared to phone apps, but it works
Old Apr 7, 2021 | 05:11 PM
04Xjrsteve's Avatar
Thank you for all of your help. I have ordered the one linked below. Will do a full report once I have a chance to see if it works.
Amazon Amazon
Chris Nystrom
Dec 30, 2020 07:31 PM
robtroxel
May 18, 2017 03:30 AM
jameson
Feb 6, 2012 06:07 AM
K.Westra
Aug 4, 2011 10:11 AM
stuartmjoseph
Aug 5, 2009 11:28 PM
