Rear side marker bulb replacement.
Old Oct 15, 2018 | 10:44 PM
toyman1001's Avatar
Default Rear side marker bulb replacement.
What is the trick to remove the plastic lens without breaking any hidden tabs on a 2005 XJ8?
Toyman
Old Oct 17, 2018 | 02:29 AM
I've moved your question from General Tech Help to X350 forum. This is the place to post techncial questions about your model.
Old Oct 17, 2018 | 08:21 AM
mhamilton's Avatar
The side lamps have spring clips at the bottom, you need to get a thin plastic blade (credit card or similar) to depress them, then tilt the bottom up. The top is held in by a plastic hook. The photo below might help. The lamp sockets in these are known to corrode and be ruined due to water intrusion, typically you'll need to replace the whole assembly. They're about $40-50 new.
Old Oct 17, 2018 | 06:32 PM
toyman1001's Avatar
Got it. Slight corrosion on one pin. Lots of electrical cleaning spray and some dialectic grease to minimize future corrosion. Replacement bulb was 194WLED which I assume is the North American equivalent to W5W from the owner's manual.
DpezXK8
Mar 7, 2024 09:36 AM
jchowell
Sep 6, 2022 04:55 PM
Johnken
Mar 22, 2022 11:49 AM
TreVoRTasmin
Jan 25, 2018 07:11 AM
rogerdodger
Dec 1, 2010 04:15 PM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
