Rough starting
Old Feb 24, 2020 | 04:22 PM
Peterinio's Avatar
Default Rough starting
Hi all. I replaced the emissions purge control valve on my 09 VDP, which took care of the engine light. It also appeared to start properly once again, but after about a week now it's beginning to crank a lot longer than it should before firing. The car also seems to run a little rough at idle. Any wild guess as to what this might be?
Much appreciated!
Peter
Old Feb 24, 2020 | 07:00 PM
abonano's Avatar
Look at fuel pressure for sure. If you haven't changed your fuel filter I would recommend doing so.
Old Feb 24, 2020 | 07:40 PM
Peterinio's Avatar
I was told there isn't a fuel filter on mine.
Old Feb 25, 2020 | 07:37 AM
Wingrider's Avatar
Peterinio, who told you that there is not a fuel filter on your Jaguar????
Who ever it was, i would ask someone else for information..
Old Feb 25, 2020 | 08:56 AM
Peterinio's Avatar
I can't imagine there isn't a fuel filter, it is probably more that it is not easly accessible. I will look into it further.
Much appreciated.
Peter
Old Feb 25, 2020 | 10:25 AM
JagV8's Avatar
Might even wonder if there is more than one...
Old Feb 25, 2020 | 10:30 AM
Peterinio's Avatar
Ok, no you're just messin with me.... : /
Old Feb 25, 2020 | 01:11 PM
JagV8's Avatar
Such as, one part way along the fuel line and one in the tank.
Old Feb 25, 2020 | 01:46 PM
Peterinio's Avatar
The dealer claims there is only one.
Old Feb 25, 2020 | 05:53 PM
JagV8's Avatar
You can trust them 100% on every tiny detail, do you think?
Old Feb 25, 2020 | 10:29 PM
Peterinio's Avatar
I think the Internet is always right so...
Old Feb 28, 2020 | 05:20 PM
Peterinio's Avatar
To re/re the fuel filter do I need to start the car and then pull the fuel pump fuse, or turn off the fuel cut off switch? Or neither? Also, is it located inside the left rear wheel well?
Peter
Old Feb 28, 2020 | 07:22 PM
Wingrider's Avatar
Under the drivers door area on both of mine, pull the plastic under cover to find
Old Feb 28, 2020 | 07:30 PM
Peterinio's Avatar
Thanks Wingrider. Is that your first or last name? : /
Old Feb 28, 2020 | 07:52 PM
Wingrider's Avatar
Neither one Peterino;
Ride & repair old Gold Wings.
Old Feb 29, 2020 | 10:30 AM
Peterinio's Avatar
I asked a friend of mine who goes by Wingman if that is his real name and he said, his name is actually Raymond but his mom being Chinese calls him Wingman so it stuck. True story.
Softball60
May 1, 2020 07:11 AM
93greenconv
Jul 27, 2014 09:04 AM
xjrwithproblems
Nov 9, 2013 02:56 PM
DBarry
Jun 24, 2013 07:45 PM
