"ticking" noise on front left ?
Old Jan 31, 2024 | 01:06 PM
nebelfuerst's Avatar
Default "ticking" noise on front left ?
My jag runs without any problems, but when I parked it today, I noticed a strange noise.
When moving my head close to the front left wheel, it sounds like a fast ticking clock.
As I opened the hood, the noise is no longer audible, as the other sounds of the engine are slightly louder.
Any ideas, what might be the source of this "ticking" ?
Old Jan 31, 2024 | 02:17 PM
mhamilton's Avatar
Could be anything, hard to know based on the description. Probably just your evap purge valve, which is completely normal.
Old Jan 31, 2024 | 04:16 PM
meirion1's Avatar
Part of he vehicle cooling down after driving it.
Old Feb 1, 2024 | 07:56 AM
mhamilton's Avatar
Some more info would be helpful to narrow it down:
Assuming it's making the noise while parked and with the engine running running, but do confirm if it's there with the engine running or shut off? Does the ticking change with engine RPM?
Old Feb 1, 2024 | 12:48 PM
"Ticking" occurs after driving below 30km/h and parking the car with engine still running.
I didn't check for a correlation with rpm yet.
I'll try to record the sound next time.
Old Feb 1, 2024 | 01:23 PM
motorcarman's Avatar
Maybe the suspension compressor?
Old Feb 3, 2024 | 07:53 PM
garethashenden's Avatar
If the engine is running, its probably the compressor. Its in front of the left front wheel.
Old Feb 5, 2024 | 06:53 AM
It's not the compressor. The sound is like a clock ticking.
I'm currently sick, so it'll take some time to do a recording, but I promise to do it
Old Feb 5, 2024 | 01:45 PM
mhamilton's Avatar
I'll bet a Coke you're hearing the evap purge valve. It's a light tick about 2x a second. It won't occur on a cold start, but only after the coolant has warmed up a bit. Will be interested to hear the sound when you get back to it
Old Feb 23, 2024 | 10:41 AM
Time for an update:
Although I have that Coke right here, I drove 3 times, but the ticking noise didn't show up.
Maybe I didn't drive that fast or the environment was colder.
I'll try to catch that sound and keep that Coke ready for delivery.
Old Mar 1, 2024 | 12:45 PM
With temperatures raising, my Jag managed to tick again.
This time I managed to do a recording by holding the microphone close to the front left wheel.
File Type: mp3
Old Mar 4, 2024 | 03:42 AM
cornishcat's Avatar
I have the same noise from my 2.7- I thought it might have been a belt or pulley- would be interested to see what responses you get as I have had to replace so many parts on my car since I bought it- Ive done less than 1000 miles in the 14 months I have owned it
Old Mar 12, 2024 | 09:22 AM
luv2fly's Avatar
Fuel Injectors?
sanchez
Jun 13, 2022 08:31 PM
wuxe
Mar 19, 2022 06:02 AM
Holy F type
Oct 28, 2019 03:51 AM
mark campbell
Oct 17, 2017 06:37 AM
