My hood release needs to be pulled to the limit of the plastic lever.
Now I am in fear, that some day the hood will no longer open.
Is there a way to tighten the hood release cable in order to gain more reserve at my plastic lever ?
roviw
close
- Join DateMar 2009
- LocationHampshire, UK
Liked:179 Times in 149 Posts
I would be inclined to look into replacing the hood cable, they can get stiff and also corroded and it makes it more difficult to open the hood/bonnet. It is better to replace it while you can actually get the bonnet open as otherwise if it eventually breaks then it is a more difficult task to get it open when you cannot use the release lever.
Been there myself so really advise you to look into it now.
roviw
close
- Join DateMar 2009
Quote:
I had one fitted in my last X350 and the one in my current X350 needs doing anytime now, due to have it done within the next couple of weeks when I have a bit of spare time to take it in. Not sure on lifespan as I suppose it depends if the cat is stored outside etc. Mine is a 2004 and I have had it for 4 years so I don’t know if it has been replaced beforeOriginally Posted by Wingrider
What's the typical lifespan?
Thanks. I'll try to get a replacement cable.
What is the correct term for this cable ? ( "hood cable" showed me books of robin hood
)roviw
close
- Join DateMar 2009
roviw
close
- Join DateMar 2009
A few years ago this guy posted this, it may help you if you are going to attempt to do the job yourself
https://www.jaguarforums.com/forum/x...-cable-153012/
Fraser Mitchell
close
- Join DateDec 2009
- LocationCrewe, England
Liked:2,548 Times in 2,021 Posts
Quote:
I'll try to do the job myself .. doesn't seem to be a quick job..
If you're reasonably good at auto-DIY, it is not a hard job. Best to try to re-route the cable a bit as Jaguar did on the later years cars. These cables just rust up and when fitting the new one, make sure you lubricate it well, something that Jaguar never did.Originally Posted by nebelfuerst
Thanks. I ordered the cable.. I'll try to do the job myself .. doesn't seem to be a quick job..
