Touch screen blank, nothing works!
Old Jul 15, 2011 | 02:13 PM
Dav1d's Avatar
Default Touch screen blank, nothing works!
It's that gorgeous touch screen that runs the AC, Nav, Audio and all the other good things. When I started the car this morning I noticed it was out, completely blank. It's always when you need the AC, isn't it?
Anyone had this problem? A nice cheap fuse replacement, or sell another kidney? Any ideas?
Many thanks
David
'04 XJ8, 32,000 miles
Old Jul 15, 2011 | 04:09 PM
jahummer's Avatar
The fuse box is in the passenger footwell. Any chance the screen was turned off in the menu? Try pressing the menu button on the right side of the screen bezel.
Old Jul 16, 2011 | 07:08 AM
Dav1d's Avatar
Thanks for the reply. I tried all of the buttons related to the screen; tried pressing the zones of the touch screen to see if the functions worked despite the loss of the picture. Nothing is working.
I've combed the fuse listings but see nothing [the theme of the day] that resembles this function although logic suggests it has one somewhere.
Again, thanks for the suggestions. Really appreciate your time - David
Old Jul 16, 2011 | 09:45 AM
jahummer's Avatar
I know the fuse for the head unit is located in the passenger footwell as I had to pull it once when the screen locked up.
Check fuse number F20 or page 205 of the Driver's Handbook.
Old Jul 16, 2011 | 09:55 AM
jahummer's Avatar
Also check fuse number F30, F34 & F38
Old Jul 17, 2011 | 11:01 AM
Dav1d's Avatar
Tried those fuses but they all looked good. I'll slowly work my way through the others so see if another is at fault.
Slowly? Yes, I'm 2 months out of back surgery and that's a crazy place to have a fuse box!
Much obliged to you, jahummer
Old Jul 17, 2011 | 11:07 AM
jahummer's Avatar
Do any of the hard buttons work? Like the radio, CDC, A/C, etc?
Old Jul 18, 2011 | 07:44 AM
Dav1d's Avatar
No, it's all dead. The only sign of life at all is "50" flashing on and off for external temperature.
Old Jul 18, 2011 | 04:12 PM
u102768's Avatar
A flashing 50 is an error code and means that the screen is not getting a response from the navigation unit in the boot.
Old Jul 19, 2011 | 07:36 AM
Dav1d's Avatar
The case is cracked! I tried the unit and found it won't eject the disc. Of course that presents a whole new challenge but at least I've a focus now!
Many, many thanks!
Old Feb 21, 2020 | 02:20 PM
thabrain's Avatar
i pressed a button on my 2006 jaguar xjr for update and screen went blank and is flashing a 51 /50 code
Old Feb 21, 2020 | 05:25 PM
JagV8's Avatar
There's a MEGA thread about it, and I think you need either a newer disc or nav module.
Old Nov 25, 2020 | 01:19 PM
Mafioso68's Avatar
I'm experiencing the same problem. Is there a reset to be done somehow? Or, dealership?
Old Nov 25, 2020 | 11:48 PM
joeleerj's Avatar
Default Mising kwi file
Go to this post and look at #14 posted by vdubelu
https://www.jaguarforums.com/forum/s...072_1-a-51699/
Old Dec 3, 2024 | 10:38 PM
Pots359v's Avatar
Hi, I have the same issue. Started the day after I replaced the 'infamous' boot harness. Camera was working, hoorah, and all was good in my xf. However, next day turned on the beast and black screen. No 50/51 code flashing.
Any help would be appreciated
Old Dec 4, 2024 | 02:12 AM
JagV8's Avatar
Look for threads about LOADING.KWI or indeed 50/51
Forcedair1
Sep 8, 2025 01:57 PM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
tberg
Sep 7, 2015 07:32 AM
philwarner
Sep 5, 2015 10:05 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
