When to replace radiator
Old Mar 9, 2022 | 03:21 PM
90 S-4's Avatar
Default When to replace radiator
2004 XJ8 106,000 mi
I'm replacing the water pump, coolant bridge, thermostat, hoses,belt & tensioner
Is now the time to R&R the radiator or could I get another 50k mi out of it.
What do you guys do/recommend ?
Also, I'd like to get a slightly cooler thermostat will that cause a problem.
It now has a 88f (190°) I'd like to get a 180°
Thanks ..
Old Mar 9, 2022 | 03:31 PM
meirion1's Avatar
See my post here:
https://www.jaguarforums.com/forum/x...ailure-256801/
Old Mar 10, 2022 | 03:22 AM
kiznarsh's Avatar
I think if you're going to address that much of the cooling system, you should go the extra step and replace the radiator and expansion tank for peace of mind.
Old Mar 10, 2022 | 05:52 AM
Wingrider's Avatar
The condition of the plastic parts is usually the deciding factor.
But as Kiznarsh posted, being pro active & replacing it now, has its merit's.
Old Mar 10, 2022 | 07:10 AM
abonano's Avatar
Originally Posted by 90 S-4
2004 XJ8 106,000 mi
Thanks ..
Change the radiator and don't change the spec of the factory thermostat
arctic_man
Jun 24, 2025 05:05 AM
90 S-4
Mar 11, 2022 04:44 PM
sixpackd
Oct 8, 2020 07:04 PM
slmskrs
Jul 31, 2015 12:04 AM
brgjag
Jan 19, 2015 11:30 AM
