Where is the fuel pressure check valve?
Old Nov 14, 2014 | 08:17 AM
panels's Avatar
Default Where is the fuel pressure check valve?
Hi All,
Been experimenting with my cold weather "no start" issue....
It's been a gradual issue based on ambient temperature. The colder it is the longer the engine needs to crank to fire off. Not a battery issue, it appears to be fuel delivery.
This morning 10 degrees. turn key to acc. count to 5, turn key off, turn key to acc. count to 5, turn key off, turn key to acc. count to five, turn to start and she fires right off.
This leads me to the residual fuel pressure. Where is the check valve that holds fuel pressure in the lines, I assume it is built into the fuel pump. So now I am thinking I need to change out the fuel pump. AARGH....
Tom
2004 XJ8 daily driver, 205K miles
PS
Found it....
Skip to 13:30 - I bet that's my issue!
Old Nov 14, 2014 | 02:56 PM
meirion1's Avatar
Don't be a pessimist like me.
Diagrams I have seen indicate it is associated with the fuel pump (which you can get to from the top of the fuel tank BTW).
However when I finally changed my fuel filter I came across a small device
right next to the filter.I have photos but they will not upload.
2w93-9s446-0311 and 135400-0311 Denso
Now if you google this code all the results describe it as a vacuum
solenoid valve because it is also used in the evap system
according to the German description.
The device shown is identical and the code matches the code in a photo.
Just one thing.....there is no electrical connection to this device on my fuel
line.
Go figure.
Old Nov 15, 2014 | 10:12 AM
DKurtti's Avatar
Access to fuel pump is under rear seat.
http://www.mediafire.com/download/9b...Powertrain.pdf
Link is for powertrain workshop manual. Fuel pump removal instructions start on page 3392. Manual also includes other possible causes of hard to start cold condition.
Isnt this great? I'm just north of you. I hope it isn't another long winter.
Old Nov 15, 2014 | 04:29 PM
meirion1's Avatar
BTW First thing is to scan for a code.
Old Nov 15, 2014 | 05:09 PM
panels's Avatar
Nope, no codes....
Its related to the amount of time the car sits and how cold it gets. Needs to "cold soak" as opposed to the usual "heat soak" issues.
Once started in the morning the car is fine starting the rest of the day as long as it's not too cold or it doesn't sit (cold soak) for say 6 to 8 hours... no issues above 30 degrees.
lets hope we have a mild winter!
This is Sweet though, the manual. I assumed I had to go through the package shelf.. this will be MUCH easier! I should have looked. the video is on and XK, must be different than the XJ
I will have to do more research on this - interesting. that just might be my issue. worth trying $30 on in any case.... THANKS
Tom
2004 XJ8
Old Nov 16, 2014 | 05:00 AM
meirion1's Avatar
No codes?
You could measure fuel pressure when it is v cold using the schrader valve
on the fuel rail.
Just a guess but should be about 50 psi.
Old Nov 16, 2014 | 08:49 AM
DKurtti's Avatar
I would definitely start with fuel pressure readings. Target is 55psi. Measure at Schrader valve (under engine cover, drivers side, has blue cap I believe) or a code reader that can read live data would work also.
Old Nov 16, 2014 | 09:10 PM
panels's Avatar
This morning... crank for 5 seconds - no start.
turned key to ignition and counted to 5 turn key off - did this three times. (build up fuel rail pressure) start car as normal on fourth turn. This tells me the fuel rail pressure is bleeding out overnight.
I do have a live data code reader - I will try that in the morning.
So... back to my original question. Does anybody know definitively where this check valve is? Is it part of the pump mechanism or a separate part in the fuel line somewhere.
Tom
Old Nov 18, 2014 | 08:01 AM
panels's Avatar
Live data reads between 54 and 57 psi. while running. so, that's good.
drops to 47 psi on engine stop?
first reading in the morning before the car is started read 52 psi this morning.
still turned the key 4-5 times to cycle the fuel pump before starting. never moved off the 52 until it started. then right to 55psi.
Tom
2004 xj8
Old Nov 18, 2014 | 03:55 PM
meirion1's Avatar
Old Nov 19, 2014 | 01:55 PM
oldmots's Avatar
If it were mine and the fuel pressure was over 50 psi after sitting all night, I would replace the fuel pressure sensor. The check valve is fine. By the way, it is a part of the pump unit. These cars do not have a return type fuel system, the sensor regulates the pump pressure.
Old Nov 13, 2015 | 11:51 AM
Lagonia's Avatar
Was there a resolution to this thread? This describes my symptoms to the tee on my '04. Trying to come up with a plan of attack...
Old Nov 14, 2015 | 10:24 AM
Don B's Avatar
Lagonia,
Have you scanned your car for any stored codes with a system capable of reading all the proprietary Jaguar Diagnostic Trouble Codes (DTCs)?
Don
Old Nov 15, 2015 | 04:31 PM
Lagonia's Avatar
Don,
My updates to this problem are kept here:
https://www.jaguarforums.com/forum/x...5/#post1348395
toronadomike
Jan 22, 2026 10:13 PM
dsnyder586
Dec 29, 2024 07:39 PM
bamforp
Aug 14, 2024 05:36 PM
Bones
Sep 8, 2015 08:34 PM
Sprayall
Sep 3, 2015 07:49 PM
