Window help
Old Sep 17, 2020 | 06:21 PM
Douglas Frisbee's Avatar
Default Window help
2004 xj8. My 4 windows And sunroof are stuck down/open. No button control for all 4 doors including sunroof. I tried replacing the switches. Still nothing. I (think) I check all fuses. Nothing. I inserted the key in door manually. Turned and held on unlock. Back two windows (previously closed) went down. When I turn to lock and hold. Nothing happens except the sunroof closes. Weird that I can not control it from interior switch. Please help.
Old Sep 17, 2020 | 07:27 PM
Wingrider's Avatar
How long have you had the Jaguar, & is this a new issue ?
If it's a new to you car, was it purchased recently from a car dealer?
Old Sep 18, 2020 | 05:27 AM
Car was from private seller and I have had it for a couple years.
Old Sep 18, 2020 | 06:47 AM
Wingrider's Avatar
A Jaguar specific reader will check the modules and give you some help in which direction.to proceed.
Old Sep 18, 2020 | 06:39 PM
jerry_hoback's Avatar
Need more info to help diagnose this. Did you do anything to the car that may have triggered the malfunction? Like a new battery, or some other electrical issue? Does the key remote fob thing still work as it should? Not sure why it would matter but maybe it needs a battery? No flooding? No hurricane activity? does the rear window lockout switch feel like it Would work if the windows did? Just trying to help think it through..... Good Luck!
mohaqq
Sep 10, 2020 04:32 PM
AlbBolivar
Jun 23, 2014 06:43 PM
kenc
Aug 31, 2013 10:11 PM
carmat731
Sep 30, 2010 10:14 AM
Feb 8, 2008 06:31 PM
