X350 rear indicator problem
Old Nov 15, 2014 | 06:40 PM
Pegassusuk's Avatar
Default X350 rear indicator problem
Hi
This is the my first post and hope someone can advise me !
I have a 2004 X350 4.2 XJ8
When I have side lights on and select left indicator the left rear bulb lights about half brightness,the right side light flashes with the left indicator light,and the rear number plate light also flashes on and off as well !
When right indicator is selected all is fine
I am inclined to think that it may be a bad earth connection .
Would appreciate any help
Many thanks
Mike
Old Nov 15, 2014 | 07:47 PM
roviw's Avatar
Sounds exactly like and earth problem, I would start by looking behind the left light fitting and finding the earth points and cleaning them up.
Old Nov 16, 2014 | 03:37 PM
meirion1's Avatar
Be careful when tightening earth points they are aluminium and often break off when
tightening
Old Nov 23, 2014 | 05:23 AM
geekman's Avatar
I've got a similar problem - it occurred around 6 months ago. I tried cleaning all the earth points but it didn't solve the issue, so I've just lived with it. If you find a solution I'd be very interested to know.
Old Nov 23, 2014 | 09:34 AM
abonano's Avatar
The ground within the rear harness supplying power/ground to the lights may be partially broken...
Old Nov 25, 2014 | 11:29 AM
geekman's Avatar
Where is the rear harness located exactly?
Old Mar 11, 2015 | 12:37 PM
Pegassusuk's Avatar
Hi
I believe that I have found the source of the fault after exhaustive checks !
The fault is in the rear fuse box situated in the o/s rear of the boot (trunk)
Undo 2 10 mm nuts holding the rear fuse box
There are a number of connector plugs connected.remove all for inspection .
I found 2 to have badly corroded pins in the blocks caused by water ingress
I was able to buy a used fuse box from EBay and cutting off the damaged plugs from the harness, rewire using leads with small spade terminals ,as I was unable to source the plugs.
The Dealers wanted to sell the complete wiring harness at silly money !
I hope this helps others who have had this fault
Best wishes
Mike
philwarner
Sep 5, 2015 10:05 AM
obwoodie
Sep 3, 2015 07:45 PM
laserguy
Sep 3, 2015 02:02 PM
OkieTim
Sep 2, 2015 12:48 PM
innzane
Sep 2, 2015 10:08 AM
