1996 xj6 sunroof won't close
Old Jan 26, 2009 | 06:56 AM
carelm's Avatar
Default RE: 1996 xj6 sunroof won't close
Hi Emerson,
1. Try to spray some lubricant on the runners to see if that helps. You're right in that it may be jammed.
2. Go to the General issues forum and download the JTIS manual from Christo's message. Kind of long, and the manual covers only 1998-2003 XJs but for sunroof issues you should be OK.
3. If it's an emergency, you can manually close the sunroof by removing the overhead garage door and sunglass panel. The sunroof motor can be turned by a screwdriver if I remember correctly. The procedure is outlined in either the owners or maintenance manuals.
4. Cover the opening with acetate and 100 mph tape until you can get it fixed
Old Jan 26, 2009 | 11:05 AM
panchostatus's Avatar
the sliders are binding up. Give the lifters a shot of lube like he said, and it should get atleast a little better.
Old Jan 26, 2009 | 02:23 PM
I'd try some white lithium grease. It's possible the track is old and has swelled in its service life.
Old Sep 22, 2010 | 11:40 AM
TopHatChef's Avatar
When you get it closed, lift it with the tilt function, slide out the headliner cover, and remove the roof panel portion. From there, you should be able to better diagnose the issue. Of course, if you do get it closed, I really suggest keeping it closed, and forgetting you even have a sunroof.
One of the cheap plastic tilt function pieces broke on mine, and I had loads of issues with it closing and sitting properly on the frame. Right now, it's shut, and I've got the $200 replacement piece in my closet waiting to have enough money/motivation to tackle it myself, or call my mechanic.
Old Sep 22, 2010 | 04:41 PM
motorcarman's Avatar
I just posted this TSB on another thread for sliding roof faults but here is the diagnostic/repair TSB 13-39
bob gauff
File Type: pdf
Old May 28, 2015 | 08:04 AM
hunterpedigo's Avatar
My 1995 Jag VP sunroof is not retracting, it's my sunroof liner, getting jammed when i retract it. Can't figure out how to get it the sunroof line to properly set. any suggestions.
Old May 28, 2015 | 08:08 AM
Your sunroof liner might be jamming like mine is doing. Tilt the sunroof up and remove the liner. It will work fine after that. But the liner keeps the heat out when it's closed.
Old Jun 2, 2015 | 09:04 AM
You should try a lubricant on the tracks, and check to make sure your sun roof liner is correctly installed. I had the same problem, and it turned out that the sunroof liner wasn't correctly in place. I had to remove it and replace it a couple of times to correct the issue.
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
99xk8guy
May 28, 2024 09:36 PM
1100me
Sep 7, 2015 06:26 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
