6x9? rear deck subwoofer
Old Apr 28, 2013 | 05:56 PM
AlbBolivar's Avatar
Default 6x9? rear deck subwoofer
Has anyone tried to fit a speaker in their Base XJ6? The Vanden Plas with premuim sound system had a Harman Kardon subwoofer.
I'm wondering if I can just fit a regular 6x9 woofer into that same cut out?
Old Apr 28, 2013 | 06:30 PM
Doug's Avatar
It'll have to be thin. Not much room between the panel and the top of the fuel tank. Only about 2.5" as I recall
Old Apr 28, 2013 | 06:34 PM
Suede's Avatar
The opening will fit a 6x9 speaker as long as it's not too deep. There isn't much space above the fuel tank. Open your trunk and peel down the carpeting on the fwd wall. You'll clearly see how much room you've got to work with (about 3 inches or so?)
Old Apr 29, 2013 | 03:21 PM
FireCrow's Avatar
That's true, there's not much space, but there's another option, after you take the shelf off (of course after removing rear seat) you'll see, that between the part you took off and the metal there's a bit of space as well, possibly around an inch if my memory serves me well. Which in theory means you should be able to put a spacer ring and that should give you an extra inch of depth Of course you'd have to put some protective foam around the ring and mounting points of the subwoofer, to make sure the shelf doesn't vibrate like mad. At least that is my plan for sound system upgrade (whenever it happens)...
Old Apr 30, 2013 | 04:19 AM
AL NZ's Avatar
It would have to have a low mounting depth
the current Alpine R-spec 6x9s have a low mount depth but are still rated about 100w RMS and 300w max - google their specs
alternatively, go subwoofer in boot
I have done this and I am happy so far. However I had to go down to 5 1/4" door speakers (JVC) which sound just fine when stationary, but underway they aint got much bass because of the road noise from our NZ coarse-chip seal.
So there is a 'hole' between the subwoofer (works up to 100Hz) and the door speakers - not great mid-range bass. So Charlie Watts' drums, Keith Richards' gritty riffs, Led Zep, the Who etc lack a bit of oomph (great bass guitar though!)
I am getting a custom MDF angled box made up at present, to go on the parcel shelf (it will be upholstered in grey vinyl to match the leather), and I will run two Alpine 6 1/2" R-spec speakers from the subwoofer amp in this box. I reckon that'll fill the gap...
Old May 1, 2013 | 12:27 AM
AlbBolivar's Avatar
That is actually going to be my plan I think.
I'm gonna try to make my own custom box to fit on the rear deck and find some shallow woofers. I think that would be the best option since the rear doesn't really have anything on top anyways.
Old May 1, 2013 | 10:55 AM
mgb4tim's Avatar
I make a subwoofer enclosure for a Gen 3 Prius (my daily driver), I'm guessing something similar for my Jaguar would be nice in the boot.
Depending on what kind of a demand the thing would bring, I'd make a mold of it and make them available in the US for a fair price. I thought about a wooden/MDF box, but they use so much room.
Attached Thumbnails 6x9? rear deck subwoofer-right56.jpg   6x9? rear deck subwoofer-right57.jpg   6x9? rear deck subwoofer-right60.jpg
Old May 1, 2013 | 11:34 AM
FireCrow's Avatar
Tim, I have an odd feeling that subwoofer in the boot of XJ6 is not the best idea... From what I've read, the sound doesn't travel that well from boot into the car... Thare's hell lot a steel and other things in the way, it's not hatchback like Focus or Prius...
Even when I installed the parking sensors, I thought to myself, I'll place the bleeping speaker in the boot, then tested it, windows closed, boot closed, engine off, and couldn't hear a thing... Then run the wires from the boot and placed that thing under the parcel shelf and it's loud as hell, even though the shelf is covering it well and I have a lot of noise from that damn clutch bearing...
By the way, Tim, did you just say BOOT, not TRUNK? :-O
Old May 1, 2013 | 12:51 PM
mgb4tim's Avatar
I did use "boot". It's a British car, right? My MGB has a boot, bonnet, and hood.
I'll have to drop a boxed sub in the trunk some time to see how it works. If it bombs, then thanks for the head up. Maybe we could port it into the back seat. hmmmm
BTW, what's a clutch?
Old May 1, 2013 | 12:56 PM
FireCrow's Avatar
Good one Tim And you know well I'm one of not many lucky guys here to own a manual X300
The seat idea sounds good Do you mean something like that thread once on the FG forum, where bloke fabricated new backrest as a subwoofer enclosure? Or are you talking only about that small space where the armrest goes? What about space under the front seats? Is there enough space for some sort of enclosure? I'm buzzing with ideas now! Mate, that's your fault!
Old May 1, 2013 | 01:52 PM
AL NZ's Avatar
I have a subwoofer in the boot and the bass gets through fine
Old May 1, 2013 | 02:25 PM
mgb4tim's Avatar
No, keep it all in the trunk, but use a ported box with a tube to the parcel shelf. Probably where the 6x9 speaker goes.
But, AL NZ says it woks fine. Maybe the FireCrow just needed a few more watts.
Old Mar 17, 2020 | 01:52 PM
X300exec's Avatar
Where would you wire the 6x9 parcel shelf speaker in,just take it from one of the rear parcel shelf speakers or door speakers ??
Old Mar 17, 2020 | 08:33 PM
motorcarman's Avatar
The original is a DUAL COIL subwoofer.
Which channel are you going to wire to?(the left or the right?)
The dual coil has BOTH channels.
More research?
Old Mar 18, 2020 | 01:08 AM
X300exec's Avatar
More research?
im only thinking of wiring a standard 6x9 speaker in there to compliment rear speakers
Old Mar 18, 2020 | 09:04 AM
But you will need to decide WHICH channel if you don't use a DUAL COIL loudspeaker.
It might sound UNBALANCED.
Old Mar 18, 2020 | 09:16 AM
X300exec's Avatar
I’ll have to find a dual coil 6x9 then
can I take the input from the little tweeters in the shelf, do they receive a full signal and adapt that at their location or do they only receive treble etc ?
dsnyder586
Dec 29, 2024 07:39 PM
H20boy
Dec 24, 2024 03:23 PM
Razor
Aug 28, 2019 08:34 PM
Darrenmb
Sep 9, 2015 09:31 PM
AL NZ
Sep 4, 2015 08:39 PM
