96 Vdp Need help
Old Feb 8, 2017 | 11:03 PM
vandenplas408's Avatar
Default 96 Vdp Need help
Need to replace the rad hose with multi connections.
need to replace rack and pinion
need to replace wire for drive door (inside)
need diys for them all
ill make my own right up for dumbies after i finish the jobs!
Old Feb 9, 2017 | 09:23 AM
aholbro1's Avatar
This may help:
https://www.jaguarforums.com/forum/x...enewal-101914/
https://www.jaguarforums.com/forum/x...-today-109984/
There may be some links in here with pics that are useful:
https://www.jaguarforums.com/forum/x...roject-100618/
Old Feb 9, 2017 | 11:08 AM
95Leaper's Avatar
The rack and pinion change should take somewhere between 60 and 90 minutes to do and it's quite simple. Use something like a turkey baster and siphon as much steering fluid out of your reservoir as possible. Get the front of the car up on jackstands high enough that you can work on it. You'll need to use a flare nut wrench on your two P/S lines connecting the rack. They'll also be an electrical connection that will have to be disconnected at some point. Disconnect both of your outer tie rod ends and also the thru bolt going to the steering column shaft. Then it's just a matter of removing the two mounts holding the rack to the frame. Make sure you take accurate measurements of the tie rod length since the outer tie rods ends will have to be removed and replaced onto your new rack. The more accurate the measurement (Making the new rack length the same as the old),the easier it will be for an alignment.
Old Feb 9, 2017 | 10:12 PM
ill make a how to thread for the hoses.
best to do them all at once.
i was gonna sell the car after repairs but its a beast may have to save it lol.
what parts / part numbers will be needed for the whole job.
Upper Rad hose
low rad hose
heater hose
water pump / gasket
thermostat / gasket
thermostat housing / gasket
rad flush
coolant
blue gasket sealant
anti seize
wire brush
sand paper 60 and 120 grits
steel wool
plastic scrapper
curved pick
Old Feb 9, 2017 | 10:29 PM
ÜRO PARTS NBC2273AB Info Water pump to Water Rail
Water Rail Goes to Back of the Water Pump
ÜRO PARTS NAC2212AA Coolant Hose Info
From Stat Housing Water Pipe
ÜRO PARTS MNA4562BB Info
Thermostat housing to expansion tank
ÜRO PARTS MNA4562AD Info
Radiator - Air Bleed "L" Shaped; Chassis Range: From 766821
ÜRO PARTS MNA4510BF Radiator Hose, Lower
ÜRO PARTS MNA4241AB Radiator Core Mount ( how many do i need)
ÜRO PARTS CBC1582 Radiator Hose, Upper
BECK/ARNLEY 1430545 {Click Info Button for Alternate/OEM Part Numbers} Includes Gasket/Seal Info
OE TEMPERATURE; TEMPERATURE 188
GATES 33613 {#1071, 30929} Thermostat Seal - 2-23/64" x 2-41/64" x 9/64" (O-Ring) Info
Thermostat Seal
ÜRO PARTS MNA6720AB HVAC Heater Hose Info
Heater Pump to Heater Valve
ÜRO PARTS MNA6722AB HVAC Heater Hose Info
Heater Valve to Firewall
ÜRO PARTS MNA6721AC HVAC Heater Hose Info
Firewall to Heater Pump
GATES 28466 {#9807, HH8466} 90º Molded Heater Hose; 5/8" x 10" (4" x 6") Info
Heater To Valve; Cut to Fit
$141.17 including shipping
