97 VDP trunk won't open - FIXED
Old Nov 30, 2011 | 10:44 AM
hdfx81's Avatar
Default 97 VDP trunk won't open - FIXED
I can't get the trunk lid open with key or inside trunk release, I disconnected the battery when I pulled the clock out and ever since then the trunk won't open everything else works fine. Any suggestions, is there any other way to open the trunk?
Old Nov 30, 2011 | 11:20 AM
BlackX300VDP's Avatar
Did you try the key in the key barrel? If you get it open, look at the wiring on the right hinge and your probably gonna need to fix it there. Pull the loom back and cut out the zip ties and inspect for broken wires. I have seen plenty and there are even more helpful tips on the wiring repair here on the forum, but i have never seen a X300/308 not open from the key barrel.
Old Nov 30, 2011 | 03:46 PM
mrleemyles's Avatar
If your completely locked out of trunk:
Remove license plate from vehicle, remove grommet from lower right(passenger) side of license plate holes in trunk lid.
Take a long thin screwdriver and slide it in and out towards the center of vehicle to try to push the latch inside.
I think I got luck it took me less than 3minutes the other day.
Others have bored large holes behind plate to get theirs open( i wouldnt do that to my car)
Old Nov 30, 2011 | 07:50 PM
hdfx81's Avatar
The key would not turn so I used the screwdriver trick and got the lid open and took out the tumbler and cleaned it really good now the trunk will open with the key. I checked the harness and could not find any broken wires so I will have to look into it further, at least I can open the trunk now. Thanks for the help.
Old Nov 30, 2011 | 08:31 PM
Good deal. Glad you got it open. The license plate trick I thought only worked on XJ40's. Learn something new every day. I will use that one if I get locked out of mine!
Old Nov 30, 2011 | 09:08 PM
aholbro1's Avatar
...I disconnected the battery when I pulled the clock out and ever since then the trunk won't open everything else works fine.
or reconnect the battery....
Granted the hinge-wiring is a problem area...and good gouge to check it out....but I thought HD was saying his electric release was working just fine until he disconnected the battery. I'll admit to some puzzlement as to what the statement "...everything else works fine.." means.....does lead one to believe the battery is reconnected....but he can't do that until he gets the bootlid open again.....Glad to hear you got in through the license plate...Can't remember who...but I think we have a member around here who discovered his prev. owner didn't get this gouge....or else needed a Jag-colored sheet metal dinner plate......
Old Nov 30, 2011 | 09:10 PM
mrleemyles's Avatar
If the vehicle is in "Valet" mode (switch in center console) wont that prevent the key or internal trunk button form opening the trunk?
Old Dec 1, 2011 | 05:33 AM
hdfx81's Avatar
I left the trunk lid open until I connected the battery again, by everything else working I mean when I lock the doors w/ key the all doors lock, alarm arms the fuel filler door locks and when I unlock them the alarm disarms, the rear doors unlock and the fuel door unlocks. Nothing changes when I mess with the valet button and I cheked the fuse for the boot lock which is also for the antenna and that works fine.
Old Dec 2, 2011 | 05:32 AM
hdfx81's Avatar
Default Problem solved
I found the problem, it was the micro switch mounted to the trunk latch. Thanks everyone for the help.
Old Dec 2, 2011 | 11:44 AM
Good find! I had one of those throw me for a loop a long time ago. The switch would have continuity when it needed it but could not work properly under a voltage load. Strange problem but i still remember it. Those switches went bad a lot too. Good find.
Old Dec 3, 2011 | 03:41 AM
Cadillac's Avatar
Thanks for the update , good to hear you found the culprit and fixed it
Old Mar 9, 2013 | 08:38 AM
motomental's Avatar
My trunk only has top
plate mounting holes. Has any one had success from top right hole???
Old Mar 9, 2013 | 09:31 AM
motomental's Avatar
Trunk saga!!! Continues . I only have upper grommets for plate holes. The plate lights buckets seem to be under the chrome Bessel.
Old Mar 9, 2013 | 09:33 AM
Nitronick's Avatar
There's a couple pieces of painted over tape covering the bottom holes. They are about four inches directly below the others.
Old Mar 9, 2013 | 10:08 AM
motomental's Avatar
Found holes thank you. How long of screwdriver would you suggest ?
Old Mar 9, 2013 | 10:12 AM
Nitronick's Avatar
I used a wire hanger with a hook bent on one end.
This is what you are trying to get to....
Old Mar 11, 2013 | 02:27 AM
motomental's Avatar
Thank you!! ;-) everything back to working order.
99xk8guy
Sep 29, 2025 10:51 PM
dsnyder586
Dec 29, 2024 07:39 PM
JarodL
Mar 7, 2024 01:39 AM
GordoCatCar
Jan 2, 2017 01:10 PM
martybmw
Apr 2, 2016 04:55 AM
