97 XJ6 L
Old Nov 10, 2017 | 05:48 PM
462 HO's Avatar
Default 97 XJ6 L
Hi all- I passed on an 89 with extremely low miles, with the helpful perspective provided on this forum.
I have found a 97 XJ6 L that is loaded, very clean and has 65k miles. It has new tires, rack and pinion was replaced 2 years ago due to a seal leak, and they found it didn't cost much more to just replace the whole thing. It does have a very recently bent auto. antenna due to them not shutting it off before the car wash. I don't know if this is a big deal to fix.
Were the 97's a good year, with lots of the bugs worked out of them by then?
What would be a good price to pay for this? It has the 4.0 motor.
Thanks!
Old Nov 10, 2017 | 08:12 PM
motorcarman's Avatar
I wish all the 1988/89 XJ40s were returned to Jaguar and salvaged for parts!!!!!!
That is just my opinion after trying to keep so many alive!!!!
The 1997 XJ6 was one of the best. The only real problem was the intermittent engine stalling that plagued the series. (well maybe the whining diff bearings also??)
Great cars as I have owned a few.
bob
Old Nov 11, 2017 | 08:25 AM
aholbro1's Avatar
Antenna is no problem. Rock Auto and others have the mast for less than $50, IIRC. Just make sure you remove all bits of the broken plastic track out of the mechanism of the old one during replacement. You may not have broken bits, but with the mast bent, you likely do.
Old Nov 11, 2017 | 07:00 PM
RJ237's Avatar
Probably the most reliable drivetrain in the history of the company. But it has to maintained, not ignored.
Old Nov 17, 2017 | 10:48 AM
dagny747's Avatar
bob
Oh, I have just started having diff bearing whine after having my rear bearings done over. Would it be louder with when accelerating and quieter coasting?
Old Nov 17, 2017 | 10:50 AM
dagny747's Avatar
If you can't figure out the mast alone, the whole thing is available from SNG for about $140 and it takes less than an hour to replace.
Old Nov 17, 2017 | 10:59 AM
dagny747's Avatar
Thanks!
Very good year, i've had mine for 17 years. The engine and transmission are generally bulletproof. I would guess between $3-5K, they have bottomed out on price and will start appreciating in the next decade or so
Old Nov 17, 2017 | 11:57 AM
Lady Penelope's Avatar
Got mine for $ 1,350 at 110 k miles , no major issues , just neglected . Look in Kelly BB online
https://www.kbb.com/jaguar/xj/1997/x...condition=good
Old Nov 17, 2017 | 12:44 PM
Probably.
The pinion bearings failing will be a higher pitched sound as the propshaft spins 3.58 times the rear wheels. The hub bearings have low pitched roar compared.
bob
