'97 XJ6 wants to stall at stops when cold
Old Mar 25, 2008 | 12:13 PM
ken@britishparts.com's Avatar
Default RE: '97 XJ6 wants to stall at stops when cold
Sounds to be as though the alternator is going south.
Old Mar 25, 2008 | 06:06 PM
FactoryJaguarTech's Avatar
The car shouldnt stall at 4000 rpms.
I agree with your assumption Ken with the lights dimming, however if 400 rpm was meant to be said, I would look at the idle control valve/solenoid. I am not sure on much on the XJ6s but I sure see alot of those valves getting changed....lol
Old Mar 25, 2008 | 06:55 PM
JagtechOhio's Avatar
gp,
FJT= Yoda!
My '97 VDP started this act about two weeks ago, although only occasionally. I haven't looked into it yet (no check engine light), but my first hunch was the idle control valve. The alternator goes off charge when the idle speed drops below somewhere around 500 RPM: any low voltmeter reading or dimming lights is an effect of the fault, not the cause. Don't throw alot of money at it unless you can identify the problem. I'll have a look at mine in the next few days, and let you know what I learn in case you haven't already gotten things straightened out.
Old Mar 25, 2008 | 08:03 PM
jag_genius's Avatar
idle air control valve failures tend to increase rpm rather then decrese. tends to keep rpms at 900-1300..
Old Mar 25, 2008 | 08:07 PM
jag_genius's Avatar
have seen ecm power relays do a similar thing.. definitly check the alternator
Old Mar 25, 2008 | 08:24 PM
Thats why I don't work on the older stuff. Everything is backward......lol
Old Mar 25, 2008 | 08:27 PM
jag_genius's Avatar
lol
Old Mar 26, 2008 | 07:29 PM
jag_genius's Avatar
car may have to problems one being alternator.. weak. and something causing it to stall. ie crank sensor, fuel problem.. ecm relay.
aholbro1
Dec 29, 2024 06:46 PM
1100me
Jul 24, 2023 06:10 PM
ccfulton
Sep 20, 2015 05:15 PM
tberg
Sep 7, 2015 07:32 AM
1100me
Sep 7, 2015 06:26 AM
