ABS Issues
Old Mar 23, 2010 | 09:20 PM
MTZGR777's Avatar
Thumbs down ABS Issues
My ABS light flickers on and off CONSTANTLY and it starting to annoy me. It worked o.k. in the winter luckily although sometimes it would cut out when I needed it most I read on a different site that the ABS Actuator is a common problem on these vehicles, do you think that may be the case with me? How much do these usually run for, I couldn't really find a price for them anywhere it was always some assembly...
Old Mar 23, 2010 | 09:38 PM
Doug's Avatar
Don't do anythng 'till you've removed the conector at the abs unit and cleaned the contacts.
Old Mar 23, 2010 | 10:58 PM
Brutal's Avatar
black tape on the I pack, the cost will total your car from the dealer. Mine comes on every 4-6 months for a day then back off. Im not worried about it as abs works fine except when the light is on.
Old Mar 24, 2010 | 06:15 PM
MTZGR777's Avatar
Thanks for the info guys.
Doug, would you be kind enough to point out where exactly the abs unit is?
BRUTAL, what is the "I" pack and by totalling my car at the dealer you mean the price would be over 3k!?!?
Old Mar 24, 2010 | 07:50 PM
Brutal's Avatar
instrument pack, and the abs module bolts to the brake valve block and pump. engine compartment in front of the left front tire wheel well. has half dozen brake lines bolted to it
Old Mar 24, 2010 | 10:06 PM
sparkenzap's Avatar
Brutal-
"engine compartment in front of the left front tire wheel well."
This is a X300, I think. Mine is near the firewall on the left, unlike the X308.
Old Mar 24, 2010 | 11:07 PM
Brutal's Avatar
sorry, yes Im thinking later model(x308)
Old Mar 25, 2010 | 12:02 AM
panchostatus's Avatar
my entire abs module is shot. i had the dealer check out the ABS codes&system.
even rebuilt ones are ridiculously espensive
its easier to drift without ABS ;]
Old Mar 25, 2010 | 11:58 AM
MTZGR777's Avatar
Yea I personally don't like it too much either...I can pump the brakes myself, I'm just tired of seeing the light.
Old Mar 25, 2010 | 12:15 PM
I don't even see mine anymore, it's been illuminated for so long.
if you're feeling zesty you can take out the gauge cluster & remove the lightbulb for the ABS light
Old Mar 25, 2010 | 08:39 PM
MTZGR777's Avatar
Is there a fuse for the ABS unit maybe that I can unplug instead?
Old Mar 25, 2010 | 10:40 PM
not that will disable the light I don't think
Old Mar 26, 2010 | 10:52 AM
Gus's Avatar
Gus
I am getting ready to begin working on my 95xj6 and thought I would look around on the x300 page. You have a lot of good information and I hope to have a little to add. I do have this information on the ABS module http://forums.jag-lovers.org/av.php?1216605k87 and a place for rebuild http://www.modulemaster.com/en/index.php I hope this helps.
Old Mar 27, 2010 | 01:36 AM
MTZGR777's Avatar
WOw! Thanks for the info.
99xk8guy
May 28, 2024 09:36 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
PMKimpton
Aug 3, 2019 08:22 PM
pocketrocket
Sep 3, 2015 07:44 PM
innzane
Sep 2, 2015 10:08 AM
