ABS light
Old Jan 16, 2012 | 12:36 PM
etaent's Avatar
Arrow ABS light
So i replaced a the bulbs in my odometer to blue bulbs and notcied one of the bulbs was burnt out. after replacing it i realized why it burnt out, it was constantly on. This light is the antilock light. I took it to my mechanic and he reconnected a cable that was disconnected by the front driverside wheel. i assume this is the wheel sensor, but the light continues to stay on. he said he scanned the abs but it reads fine and told me i should drive atleast 200 miles and then the light will shut off, anyone else have any ideas?
Old Jan 16, 2012 | 07:59 PM
aholbro1's Avatar
Hate to be Mr. Obvious...but did he have the proper tool to scan chassis codes? WDS/IDS?AE w/Jag module are about all that will do it. Std. OBDII Tools will only get you Powertrain ("P") codes....
Hint: If the ABS light is on, all is not "fine"
The best way to proceed is to get the code and go from there, but C1095 is pretty common, and the cause is normally broken solder joints on the board. I'll see if I can find the link and edit back here, for you.
Here it is: https://www.jaguarforums.com/forum/x...c-fault-44272/
Searches on 3 characters or less don't work...but if you want "everything" on ABS you can search with leading and trailing "*" ie. "*ABS*" I got 114 hits in the x300 section this way, so have fun!
Old Jan 17, 2012 | 08:50 AM
etaent's Avatar
Ahol i couldnt agree with you more! I definetly agree with you that its not fine, i believe my mechanic just doesnt have the means to really scan the abs and see what the problem is. that being said, the only way i will be able to find out what the issue is, is to take it to the dealer?
Old Jan 17, 2012 | 09:14 AM
sparkenzap's Avatar
ETA-
A good many Jag independents have the correct scanning softwar to ID the ABS faults. In additon to the ones aholbro mentioned, AutoEnginuity w/ Jag extensions and the Snap On high end unit, among others will read them. If you have reconnected the wire, try doing a hard boot. Then, if the light initially goes off, carefully observe when it comes back on. If it is at about 10 -12 mph, the problem is likely a wheel sensor,
But as suggested by ahol, you should get the codes read before spending time or money trying to fix it. The scan should cost a shop's minimum labor, since it should take about 1/4 hr. That minimum is usually 1/2 or 1 hour.
Old Jan 17, 2012 | 11:56 AM
freda155's Avatar
It should not take that many miles to turn off the anti lock light. Just reaching 20 km/h is enough for the systems self check to complete.
If the ABS ECU is defective, it can be repaired for about $100. I used AutoXpressTech a few years ago. ABS has been working fine ever since.
Old Jan 24, 2012 | 03:33 PM
etaent's Avatar
So does anyone know the process of cleaning the wheel sensors or how many this car has? im assuming 4 but before i get down and dirty i need to be sure. thanks guys!
Old Jan 24, 2012 | 09:28 PM
dad2twins's Avatar
Rev. Sam has some very good videos on youtube that covers the wheel sensor cleaning.....among other things as well.
Old Jan 30, 2012 | 09:14 AM
etaent's Avatar
thanks dad2twins! i found plenty of info on how to clean them and their location! However this didnt rectify the situation, im gonna have to wait to get it scanned for chassis codes as i only have an obdII reader.
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
redrover41
23
Sep 25, 2015 01:33 PM
avern1
Sep 8, 2015 06:25 PM
innzane
Sep 2, 2015 10:08 AM
