AC stopped working
Old Aug 25, 2011 | 12:14 AM
mrite04's Avatar
Default AC stopped working
I have a 97 XJR with about 55000 miles, the ac stopped working a few thousands miles ago, the car was hardley driven in the summer and that's why I didn't takckle the problem. Since the car has low miles, I'm not suspecting the problem to be with the freon. I would like to first jump the compressor, but I don't know which one is the ac relay and how to jump it, that is unless somebody thinks I should start eleswhere. Thank you in advance.
Old Aug 25, 2011 | 03:14 AM
Cadillac's Avatar
Hey, there is another thread about this , check this out
https://www.jaguarforums.com/forum/x...working-58992/
Old Aug 25, 2011 | 09:18 AM
pan84's Avatar
If compressor clutch not kick in, probably bad fuse, relay or low freon. You need hook up gauges and you can see what happens, low freon or any problem in the system (if compressor engage but not cold), like blockage or expansion valve bad. On my jaguar with 65 ooo miles valve got stuck.
Old Aug 25, 2011 | 11:58 PM
mrite04's Avatar
The compressor is not kicking on, and I just hooked up the gauges, low is (40) and high is (0). I Thought both sides should read the same when
compressor is not on. So what do guys think?
BTW I did read the thread that was started by pan84, good thread but doesn't get into what to do when the compressor is not engaging.
Old Aug 26, 2011 | 07:25 AM
pan84's Avatar
You have no freon
Old Aug 26, 2011 | 04:44 PM
alabbasi's Avatar
If the compressor is not engaging, put some gauges on the system and see if you have pressure. If not then pressure switch will cut power to the compressor so as to prevent damage (there is usually a high pressure switch and a low pressure switch). If there is freon, then it could be a relay or the compressor itself. You can try jumping the compressor by giving it power directly from the battery to see if it works.
Old Aug 27, 2011 | 02:45 AM
mrite04's Avatar
Question for pan84
just wondering, if the low side is reading 40lb, you still think the freon is empty,
also wondering why the pressure is only showing on the low side.
Old Aug 27, 2011 | 02:50 AM
mrite04's Avatar
Default for alabbasi
alabbasi, did you read post #4? I did the gauge hook up and only getting 40 lb
reading on the low side and 0 lb on the high side.
Old Aug 28, 2011 | 03:07 AM
alabbasi's Avatar
That would either indicate that you have some sort of blockage or that the gauge is not connected properly. I suspect that the gauge is not connected properly.
Check the connection and make sure that the valve on the fitting is opening.
40psi on the low side when the compressor is not running is too low which would indicate that you are low on freon.... but I would still expect to read pressure on the high side.
A general rule is about 35-40psi on the low side and 2-2.5 times the outside temp on the high side (so if it's 100 degrees outside, you should read between 200-250psi on the high side).
Good luck.
Old Aug 28, 2011 | 06:03 PM
mrite04's Avatar
Thank you alabbasi, I will check the high side connection again. I knew that 40 psi on the low side was low (compressor off), but I couldn't understand the 0 reading on the high side.
Old Aug 29, 2011 | 12:29 AM
pan84's Avatar
Originally Posted by mrite04
Question for pan84
If high side 0 and low 40, its low enough to say empty
Probably blockage in the system, or high side not connected properly
Forcedair1
Sep 8, 2025 01:57 PM
PMKimpton
Aug 3, 2019 08:22 PM
tberg
Sep 7, 2015 07:32 AM
philwarner
Sep 5, 2015 10:05 AM
Chet Ramnarain (bozzner)
Sep 3, 2015 12:21 PM
