Adding oil to differential
Old Apr 25, 2021 | 10:22 PM
Alan E L's Avatar
Default Adding oil to differential
Hi all,
My high mileage 3.2. X300 has a weep from the differential half shaft.
I have can’t find the filler / level plug on the differential to top it up.
I presume it is on the aluminium finned back plate below the breather but I cannot see itIs this correct and is it easily accessible without major disassembly?
with thanks
Alan
Old Apr 25, 2021 | 10:39 PM
Jagboi64's Avatar
Yes, in the rear cover plate. Should be a plug with a 3/8" ( I think) square recessed hole. It's either 3/8" or 1/2" so a standard ratchet head fits in it.
Old Apr 25, 2021 | 11:20 PM
Parker 2's Avatar
Some have drilled a hole in the trunk floor pan
Old Apr 30, 2021 | 10:23 PM
Don B's Avatar
Hi Alan,
Here's a photo from eBay showing the rear cover of the GKN Salisbury 15HU differential in your Jaguar. The fill plug is the round rusty part at the lower right with the square hole in it:
Like Jagboi64, I can't remember if the hole is 3/8" or 1/2" square, but a standard ratchet or breaker bar will fit it. You may need a short extension.
If you want to change the oil, and your drain plug has a 1/2" square head, you can slide a 1/2" socket extension onto it and use an adjustable wrench on the other end to turn the plug out.
The leak from the half shaft seal usually indicates that the output shaft bearing is worn. It can be replaced without removing the differential.
Cheers,
Don
Old Apr 30, 2021 | 10:56 PM
xalty's Avatar
1/2 square
if you have the monostrut you need a wobble extension
Rickcusaf
Mar 7, 2018 03:55 PM
Eagle180
Aug 23, 2017 10:14 AM
biffta
May 10, 2015 08:19 PM
David7
Apr 15, 2015 09:42 PM
Dave2254
Sep 2, 2014 07:11 AM
