Alternator gone bad?
Old Aug 11, 2022 | 10:37 AM
gibbon's Avatar
Default Alternator gone bad?
Hi all.
Just noticed that the dash voltmeter is showing around 11 volts while driving. Red light on dash is not on. Put meter on battery and it reads 11.78 at idle. Increasing revs does not alter the reading.
I also put the meter on the live side of the fuses in the engine compartment located drivers side front. This showed the same when engine revs increased.
Voltage regulator bad?
Old Aug 13, 2022 | 01:07 AM
Parker 7's Avatar
Originally Posted by gibbon
Hi all.
the voltage regulator fuse ( right engine bay fuse box # 10 red 5 amp ) can sometimes blow from the systems that this fuse is tied into
It is true that the voltage regulator takes power to make the alternator produce power in the form of the correct voltage of between 13.5 to 14.5 volts with the engine running
the 11 volts you are seeing should instantly be used to produce a alternator output in the 13.5 and up range
The 11 volts is most likely the battery voltage at that stage after draining from a start , that alternator is most likely produsing under 11 volts or none at all
so this points to the regulator
the red light enable comes from inside the regulator and should be showing
IN435 is replaceable but you have to remove the alternator
I did not have luck with E - bay sellers as they would send the wrong part # so I went with a brick and motor store I'll have to find again
The instrument cluster voltage gauge comes from the .........................................
Old Aug 13, 2022 | 12:33 PM
gibbon's Avatar
Hi Parker 7
I think this is the voltage regulator https://store.alternatorparts.com/in...regulator.aspx
Just going to check the fuse and maybe start removing the alternator.
Thanks for you help
Old Aug 13, 2022 | 01:00 PM
Parker 7's Avatar
Yes on the source
the auto parts stores can spin up the removed alternator and give you a report on the different aspect of the alternator / VR assembly on or off ( removed ) from the car
the alternator removes from the top only but you have to go under to remove the long pivot bolt
keep track of the position of the single wires that go to the alternator noise suppressor , one will be a large terninal end to the alternator B+ post
not all X300s have this noise suppressor
the pivot bolt has 1 short shouldered bushing that stays in place
you may have to pry the alternator out of the engine mount bracket ( pinched )
Old Aug 13, 2022 | 01:20 PM
Parker 7's Avatar
Old Aug 13, 2022 | 03:41 PM
gibbon's Avatar
Checked the fuse as mentioned previously, and was ok. Got the Alternator out. Brushes have about 3/16" left on them.
Think I will get the regulator and new brushes.
Ian
Old Aug 13, 2022 | 03:53 PM
Parker 7's Avatar
there has been history of the B + heavy wire to the starter solenoid tie in point being loose at the solenoid
that is the first alternator connection aft of the alternator B + terminal
13 mm socket on a 3 inch extension and is the upper of the 2 / 13 mm nuts
This is looking down through the intake manifold pipes
Old Aug 15, 2022 | 10:33 AM
Don B's Avatar
Ian
While you have the alternator out, it would be prudent to also replace the shaft bearings.
Cheers,
Don
Old Aug 15, 2022 | 10:38 AM
Parker 7's Avatar
I found a local alternator shop to replace the bearings in mine as they had gone out
They had a different source and manufacture for the IN435 Voltage Regular that I have written down somewhere
Old Aug 21, 2022 | 03:43 PM
gibbon's Avatar
Hi all.
Took the alternator to the repair guy. One of the Diodes was totally fried, and the voltage regulator was giving out weird voltages.
New diode pack, brushes and regulator and back in car. All is good now.
Thanks to Parker 7 and Don B for your input.
Ian
Harry Peter Rose
Aug 8, 2022 05:37 PM
laguillotine
Mar 24, 2021 07:26 AM
Todd Wiens
Dec 10, 2019 04:24 PM
Alster370
May 29, 2017 11:30 AM
sgb
Mar 29, 2010 08:33 PM
