auto trans warning light on
Old Jun 17, 2019 | 02:22 AM
spurs's Avatar
Default auto trans warning light on
hi all, half way home today the auto trans warning light came on. i did notice the gear changes were a bit rough. when i got home i put about 600mls of fluid in and took it for a drive. gear changes seemed to be ok but light still on. does it need more fluid or is it something else.
Old Jun 17, 2019 | 09:31 AM
motorcarman's Avatar
There will be DTCs in the TCM (Transmission Control Module).
I suggest reading the codes and diagnosing from there.
A regular OBDII reader will not access the gearbox module.
bob
Old Jun 17, 2019 | 02:40 PM
spurs's Avatar
hi, dont have one of those code readers yet.
Old Jun 17, 2019 | 03:28 PM
Marc-XJ12's Avatar
Hi, I have read quite a few posts about the electrical connector on the back of the gearbox causing dash light on and harsh shifting, the harness doesn’t have much play in it and as the engine/gearbox rear mount gets old the gearbox will move around more.
I'm planning to change mine as the Bush and spring are still available and not too many £££/$$$$ in the grand scheme of these cars
Old Jun 17, 2019 | 03:53 PM
spurs's Avatar
hi, thanks for the info on that switch. will get under there and give it a good clean and see if that fixes it.
butkusandbale
Apr 19, 2015 04:02 PM
slmskrs
Nov 12, 2013 02:08 AM
JLee
Oct 6, 2012 09:46 AM
wannesd
Mar 6, 2010 09:12 AM
