Boot release not working properly.
Old Aug 7, 2023 | 03:39 AM
Spud Maat's Avatar
Default Boot release not working properly.
So,
something that has just started happening recently is my boot release is not working properly.
when i turn the key the latch lets go and the boot pops up nicely.
however when i push the button on the dash, the button on the boot or the button on the remote the boot does not pop up.
the actuator works you can hear it going, and it kind releases.
like i can pull the put open. it is unlocking it it but when i go to pull it up it feels it is stuck then it releases.
so in short the electronic boot release is not properly popping the boot.
is there some kind of adjustment on the actuator at all?
or is it something that would require an actuator replacement?
Old Aug 7, 2023 | 08:09 AM
Parker 7's Avatar
Something about the ends of the rods as it hooks into things
Brain just waking up
Old Aug 7, 2023 | 09:13 AM
Spud Maat's Avatar
maybe there is an adjustment to screw it tighter you think?
might have to try and get in there and have a look at some point.
have to try and see what rod it pulls.
wonder if there are and images around.
i am not sure if my brain ever wakes up.
certainly needs a couple of coffees first....
anyway off to bed for me
Old Aug 7, 2023 | 10:17 AM
Parker 7's Avatar
There are some pics on earlier posts
The actuator pulls the rods to the cars right
Still can't think , time for a big honker Gyro
This is a pic of the center latch mechanism , you don't have to get the fire ax out
Old Aug 7, 2023 | 04:44 PM
Spud Maat's Avatar
Haha yeah no fire axe will be used.
def remove boot carpet and look that way
i assume one of those rods is from the mechanical mechansim (lock barrel) and the other is from the electronic mechanisim (actuator from the button)
Old Aug 7, 2023 | 05:35 PM
Parker 7's Avatar
The actuator and rods are in the trunk lid
Can't remember the details on the rod ends
Old Aug 7, 2023 | 06:17 PM
Spud Maat's Avatar
yeah know the system kinda from when i repaired the boot key lock.
so should be able to have a good look and work it our easy enough
Old Aug 8, 2023 | 01:24 AM
SleekJag12's Avatar
SPUD... Have you tried adjusting the striker a small amount? It is very fiddly adjustment but might improve the unlatching at the sweet spot.
I wonder if the trunk struts wearing out makes any difference as they push upward slightly. My lid raises only very slightly at unlocking.
LOVE the fire ax post #4 Parker! Hilarious. Looks like someone actually did that?
Old Aug 8, 2023 | 03:43 AM
Spud Maat's Avatar
have not looked at trying to adjust the striker at all. i was thinking that maybe thats it, but, when turning the key the striker does release properly and the boot does pop up.
don't think the struts would cause anything, but possible. its not like they are gas struts like under the bonnet.
and when you say adjust the striker what do yo mean? like shifiting it a little to the left or right?
because maybe that could be it.
maybe when i was fixing something i have put it back in the wrong place and did not notice.
Old Aug 9, 2023 | 03:10 AM
Parker 7's Avatar
" LOVE the fire ax post #4 Parker! Hilarious. Looks like someone actually did that? "
Someone did and he got after me in posting his pic
Old Aug 19, 2023 | 08:50 AM
Spud Maat's Avatar
ok so repaired. very very easy fix.
the top rod is the one that attaches to the actuator.
there is no adjustment on the rod.
what i did was simply remove the actuator and bracket,
remove the actuator from the bracket.
drill out the mounting holes to offer some adjustment
re mounted the actuator so it sits further over on the bracket and closer to the RHS of the bootlid.
re mounted the bracket to the boot.
viola. perfect.
basically in short i just enlarged the holes on the bracket so the actuator could be mounted further away from the latch enabling the rod to have more pull.
Attached Thumbnails Boot release not working properly.-s__110469177.jpg   Boot release not working properly.-s__110469175.jpg
manycars
Dec 3, 2024 10:25 AM
sil9090
XK120 XK140 XK150
Sep 2, 2021 07:02 AM
SamtheSham
Jun 22, 2021 07:18 AM
joebit
Oct 24, 2020 04:11 PM
BDuncan
Nov 21, 2019 03:16 PM
