Broken wires in trunk
Old Jun 3, 2014 | 04:40 PM
Satterfield's Avatar
Smile Broken wires in trunk
Does anyone know where all those wires go in the trunk right side ,the ones in the hinge cover, i have four broken, no trunk lights and one tag light, thanks , Satterfield
Old Jun 3, 2014 | 06:05 PM
Suede's Avatar
Yep, you've figured out where they go. To the 2 trunk lid lights and tag lights. Best bet is to measure out 2 inch lengths of wire then solder on & wrap in electrical tape. Anything less than 2 inches gets a little frustrating to work with.
Old Jun 4, 2014 | 08:14 AM
mgb4tim's Avatar
I just metered out the wires in the rear light control box to figure out where to tap off for a trailer wiring harness (brake, directional, running, reverse). I wanted to draw up a "map" of the connectors to show what powers what light. Maybe I'll move forward on that project over the weekend.
Old Jun 4, 2014 | 09:02 AM
That would help alot, Thanks, Satterfield
Old Jun 18, 2014 | 09:11 AM
mgb4tim's Avatar
I haven't forgotten about you. The hitch and wiring module came yesterday - finally. So, I should have that map done very soon - that's if I ever want to move my utility trailer again.
Old Jun 18, 2014 | 06:40 PM
Thanks, Satterfield
Old Jun 24, 2014 | 08:14 AM
mgb4tim's Avatar
Here you go - the rear lights that I tested on the white connector at the rear light computer.
I tapped these wires to control a wiring harness module for trailer lights. Luckily, in the US for a 4-pin connector, I only needed the tail, indicator, and brake lights. No needs for reverse or rear fogs.
Old Jun 25, 2014 | 07:11 AM
Thanks Tim,i am sure it will help me ,a little visual goes a long way, Satterfield
Old Jun 25, 2014 | 07:45 AM
thorpyuk's Avatar
Hi all, sorry to hijak the thread, but my boot/trunk lights are hanging down, and not fixed - there doesn't seem to be anything there to fix them to, is there a couple of fixings i can buy to secure them?
Thanks!
Old Jun 26, 2014 | 03:10 PM
b1mcp's Avatar
No. They should be glued to the boot trim. That's how they come from the factory.
Old Jun 27, 2014 | 05:34 AM
thorpyuk's Avatar
Problem is that the holes are bigger than the lights, so there's obviously something missing somewhere...
Old Jun 27, 2014 | 06:46 AM
there is a bracket of sort their , satterfield
Old Jun 27, 2014 | 04:41 PM
b1mcp's Avatar
Sorry, my last post probably wasn't very clear. I didn't mean the lights are glued, I meant the brackets were glued, they are part of the trim so you can't buy them separately.
There is just a sort of frame around the aperture in the trim. See the picture here
X300/XJ6 boot light inspection ~ Jaguar Vanden Plas "The cats meow"
Check inside your boot trim, they may have fallen off and just need gluing back on. The lights just clip to these - no other brackets.
BadKat174
May 26, 2023 12:29 AM
mbergen
Oct 23, 2019 10:26 PM
DuhCar
Sep 11, 2015 10:58 AM
al_roethlisberger
Sep 9, 2015 09:14 PM
avern1
Sep 8, 2015 06:25 PM
