Car will not start
Old Jan 24, 2013 | 11:43 AM
JagfanNYC's Avatar
Default Car will not start
I have a 1995 XJ6 it has always started since I bought the car now it will not start. I thought it was the battery because its 10 deg outside right now and the last time I drove the car was last Friday. I got a boost but it didn't help. So I am thinking maybe either the fuel pump ICM or CPS? I had an issue with the CPS on my last car and it had the same symptoms as the JAG has now.
Old Jan 24, 2013 | 01:11 PM
RJ237's Avatar
You need to buy a cheap code reader or borrow one to see if there are any clues. I think the cps would throw a code.
Old Jan 24, 2013 | 01:51 PM
Doug's Avatar
One possible clue:
If the tach needle does not bounce a little while cranking, it's likely the crank sensor that has failed.
Note that if the needle does bounce it doesn't positively prove the CPS is good. But, if it doesn't bounce, I'd go ahead and replace the CPS.
Old Jan 24, 2013 | 02:48 PM
abonano's Avatar
+1 on CPS and a bigger +1 leaning towards the fuel pump or partially blocked fuel filter if the CPS checks out.
Old Jan 24, 2013 | 05:23 PM
JagfanNYC's Avatar
Originally Posted by Doug
One possible clue:
I did look for a tach signal when I started the car. I forgot to write that when I started this thread. the needle does move when the car is cranking.
Old Feb 2, 2013 | 04:43 PM
JagfanNYC's Avatar
One possible clue:
The car is still not starting, I do watch the tach when I am trying to start the car. The needle does bounce but just a little. I am hoping its the CPS because I can replace that myself. Is there a way of testing the cps?
Old Feb 3, 2013 | 01:19 PM
rrainey86's Avatar
Found your thread by researching. Not a Jag specialist and I am looking into owning one. But, you can narrow down with some starting fluid. On my other cars I disconnect the intake hose at the throttle body(avoid sensors like the MAF as it can damage them) and spray starting fluid in the Throttle body. It should at least try to crank if not crank since you have air sensors disconnected from the system. This can help rule out fuel related issues if it still doesnt crank. Again Im sure others will correct me if this is wrong or bad as Im not familiar with Jags but I do this on all my cars when trouble shooting. Again just trying to help and Im sure I will be corrected if this is bad.
Old Feb 3, 2013 | 08:10 PM
JagfanNYC's Avatar
The car is cranking so that rules out the starter. I will try some starting fluid, I am thinking its the CPS. Before the starting issue the car ran just fine. When my CPS went out on my last car I had the same symptoms.
Old Feb 7, 2013 | 02:30 PM
JagfanNYC's Avatar
I checked the fuel pump relay and its clicking so I know its working. I also heard the fuel pump hiss when I turned the key. I also put in a new fuse for the fuel pump as well. So I am pretty sure that rules out the fuel pump. I think its time for a new CPS. Can I test the current CPS before buying a new one?
Old Feb 12, 2013 | 09:28 PM
JagfanNYC's Avatar
I am back, I bought a new CPS but I ran out of daylight to install it. But my problem is to unclip the connector whats the best way to do that? I will try with a screw driver. Anybody have any other tips?
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
Jaguila
Sep 5, 2015 06:16 PM
1964Daimler
Sep 2, 2015 11:41 PM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
