Check Engine Light
Old Jul 12, 2010 | 08:32 AM
XJR96's Avatar
Default Check Engine Light
Check Engine light has been on for awhile I believe i corrected the problem it was addressing but still hasn't gone off any suggestions? 1996 XJR
Old Jul 12, 2010 | 09:01 AM
Drew's Avatar
Disconnect the battery and that should clear the code. If it comes back on you still have a problem.
Old Jul 12, 2010 | 09:39 AM
XJR96's Avatar
ill try that thanks
Old Jul 12, 2010 | 10:12 AM
Brutal's Avatar
Originally Posted by drew
disconnect the battery and that should clear the code. If it comes back on you still have a problem.
not on obdII, thats old school, doesnt work. You might get the light off after so many key cycles depending on code. But it will be stored and continue to come on from time to time. Go buy a obdII scanner, and clear it yourself the right way. Then you have for next time, theyre cheap $40+
Old Jul 12, 2010 | 11:35 AM
XJR96's Avatar
Ok ill check that out
Old Jul 12, 2010 | 02:35 PM
poor boy's Avatar
Talking codes?
Last Summer after sitting all Winter, (I rarely drive my X300 during the Winter, maybe 15 or 20 miles between Nov. and April) as at this time there is absolutely no rust in or on the car, but when I did start it in the Spring the check engine light came on.
After procrastinating taking the car in to the shop for about a month the light went off while I was driving the car and has never come back on in over a year. As to this day I don't know what made it come on. If it does come on again I will make a bee line to the shop.
Old Jul 12, 2010 | 02:58 PM
TopHatChef's Avatar
I had that happen a bit with mine. It was the code for an O2 sensor. I had it read, and a week later, it went off. About a month went by and it came back on. I replaced it, and after a bit of driving, the light went off.
Old Jul 13, 2010 | 10:07 AM
Drew's Avatar
Does anyone know what year Jaguar went to OBDII?
Old Jul 13, 2010 | 10:27 AM
Doug's Avatar
1995...on the USA X300 6 cylinder cars, at least.
BrentGardner
29
Dec 16, 2024 12:13 AM
big d
Sep 3, 2015 07:37 PM
niner nellie
Sep 1, 2015 10:53 PM
tony bosco
Sep 1, 2015 02:06 PM
daro31
Aug 27, 2015 09:26 AM
