Clunk clunk clunk
Old Oct 4, 2014 | 10:29 AM
Lawrence's Avatar
Default Clunk clunk clunk
Hi Guys, I have a 94 XJ40 with the X300 rear suspension arrangement.
I've got a persistent clunk over ruts and potholes but car is nice and smooth on the highway. In the front, I've replaced the shocks and both upper cushions and and lower shock bushes, all OEM.
In the rear, I've replaced the shocks (Bilstein), so lower bushes and upper isolators got done too.
After replacing all this stuff, the clunk still was still there, maybe not as severe for sure, but she still isn't riding like I imagine it should.
Chasing down this clunk and not getting anywhere, I replaced the rear springs and the large sub-frame mounts, again all OEM.
Still clunky - bummer!
Any ideas?
Larry
Old Oct 4, 2014 | 10:47 AM
Don B's Avatar
Larry,
Rear shock upper bushings are the most common cause, but you've renewed those. I can't recall if you addressed the driveshaft center bearing or transmission mount, but those come to mind.
Don
Old Oct 4, 2014 | 10:54 AM
Lawrence's Avatar
Originally Posted by Don B
Larry,
Don
I guess those are next - I do have vibration on deceleration which I've read is a symptom of centre bearing ..How do I check the trans mount? how much movement is "normal"?
Cheers Don
Larry
Old Oct 4, 2014 | 12:17 PM
Don B's Avatar
I don't know if there's a spec for movement, but if you've never rebuilt the transmission mount, it's time... It's not hard, just look up the info in the Jag-Lovers archive about the mistake in Haynes about the order in which to reassemble the parts. I think Groove was one guy who made note of it.
Here are photos showing the driveshaft center bearing replacement:
Welcome to Jag-lovers - Members Photo Viewing Page
Cheers,
Don
Old Oct 4, 2014 | 12:54 PM
manwich66's Avatar
Default it's prybar time
Hey Larry,set the stands under each side of the rear suspension,so it is loaded with the weight of the car,good lighting,and a long heel bar.
With a little careful prying,you will spot the metal to metal contact point.
Good idea to check exhaust hangers too.
After I replaced the rears in Cin's car,there was a noticeable 'thup thup' going over speed bumps etc.,but after some miles on the new goodies,things have settled down
Hang in there!
Jim an Cindy
Old Oct 4, 2014 | 02:13 PM
Lawrence's Avatar
Cheers,
Don
Hi Don, already had a look at your centre bearing pages last night, looks doable and on the cards for sure ..the trans mount, well, I need to see what parts need replacing in that unit and where I can source them. Looks like less of a "big job" than the centre bearing so probably that'll be first on the list - the cold weather approaches and I'm working under a carport so hopefully I can get on with these jobs before the deluge comes along!
cheers
Larry
Old Oct 4, 2014 | 02:17 PM
Lawrence's Avatar
Hang in there!
Jim an Cindy
Hey Jim, prybar it is, we'll have another look on Monday!
This undercarriage stuff is never ending, ain't it - I can see why Don replaced everything on his car now!!!
all the best
Larry
Old Oct 4, 2014 | 02:21 PM
Don B's Avatar
Our '93 still has issues, but none of them has to do with a bushing or bearing!
Razor
Aug 28, 2019 08:34 PM
British Ride
XJ40 ( XJ81 )
Nov 28, 2015 03:50 PM
Chuck Schexnayder
33
Oct 24, 2015 10:20 PM
Vincentbrough
Sep 24, 2015 01:12 PM
philwarner
Sep 16, 2015 10:40 PM
