Eddiec
Old Dec 8, 2020 | 07:44 AM
Eddiec's Avatar
Default Eddiec
I have a 1996 Jaguar XJR 6 called. Super Charge. My mechanic says it requires new sets of fuel injectors.
Can I use any XJ fuel injector model? Is an aftermarket reliable. I don't use the car in the winter.
Old Dec 8, 2020 | 01:39 PM
xalty's Avatar
no you need the 36lb/380cc injectors for the XJR. D3165AA or D3165KA are the factory jag numbers but very expensive. D3165BA may also work and is a lot cheaper.
https://www.racetronix.biz/p/37-lb-h...jector/d3165ba
Old Dec 8, 2020 | 05:27 PM
Don B's Avatar
Hi Eddiec,
Welcome to the Jaguar Forums! It's great to have you with us!
Please visit the New Member Area - Intro a MUST and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome.
The Jaguar part number for the 380cc/min Lucas/Bosch D3165AA injectors that xalty mentioned is DBC11041. The latest superseded part number appears to be LNA1520BA. Jaguarclassicparts.com shows them as no longer available (NLA), but jaguarparts.com lists them as available for $274.95 each (!)
Let me know if you can't find a good deal on a set of new injectors. I may have a full set of New Old Stock D3165AA in my parts bins.
Cheers,
Don
Old Dec 8, 2020 | 06:14 PM
Eddiec's Avatar
Default 1996 jaguar xjr 6 cyl supercharge.
Hi Don, I'd like to get the car 🚗 going so I can put it on storage for the winter.
if its compatible, please let me know your price.
Eddiec
Old Dec 8, 2020 | 09:10 PM
Don B's Avatar
I'll see if I can find them and if so, will send you a Private Message. Give me a couple of days - I'm in the middle of a major engine repair on a Mercedes.
Cheers,
Don
Old Dec 8, 2020 | 10:07 PM
Eddiec's Avatar
Thanks Don. Appreciate it.
kindly email me directly at
Old Dec 9, 2020 | 09:42 AM
Mkii250's Avatar
Not to be a downer...Hi Eddie and welcome...I hope you are sure about needing all six. In the past I have taken mine for a rebuild and bench test ($25 each) and found I only had to replace one. Just wouldn't want to see you throwing parts at a car that may not need them, can leave a bad taste eventually.
Old Dec 9, 2020 | 05:38 PM
b1mcp's Avatar
I have to agree with Greg. It would be very unusual to need all 6 injectors at the same time just from normal wear and tear. Is there something particular about car's history that we don't know?
Old Dec 9, 2020 | 06:12 PM
Eddiec's Avatar
Hi Don,
my mechanic says he would like to replace all 6.
Please give me an excellent price.
kind regards.
Ed
Old Dec 10, 2020 | 08:18 AM
Mkii250's Avatar
Rockauto.com has injectors that fit your XJR for $33CAD each. Different brands go up from there. Maybe keep the old ones, rebuild if/when you need them again.
Old Dec 10, 2020 | 08:19 AM
Mkii250's Avatar
I didn't realize until now how inexpensive they can be!
Old Dec 12, 2020 | 02:57 PM
Bonn's Avatar
Hadn't heard of Rockauto.
What a great website!
Thanks, Mkii250
Old Dec 12, 2020 | 03:18 PM
Jagboi64's Avatar
Rockauto is great, however, the listings are not always 100% accurate. The XJR is a unique injector, make sure that is isn't lumped in with the XJ6 as being the same.
Old Dec 12, 2020 | 03:30 PM
Bonn's Avatar
My dyno guy tells me I need to go 'the next size up' on injectors, including set-up sheets, etc. Any recommendations?
Old Dec 17, 2020 | 11:52 AM
Eddiec's Avatar
Default 1996 jaguar xjr 6 cyl supercharge. H
Originally Posted by Don B
Hi Eddiec,
Cheers,
Don
Hi Don,
Its EddieC. Just wondering if I can still buy the new old stock D3165AA you've mentioned.
please advise ASAP.
THANKS.
Eddiec
Old Dec 17, 2020 | 12:01 PM
Eddiec's Avatar
Hi Eddiec,
Cheers,
Don
Hi Don,
please advise ASAP.
THANKS.
Eddiec
Old Dec 17, 2020 | 02:47 PM
Don B's Avatar
Hi Don,
please advise ASAP.
THANKS.
Eddiec
Hi Eddie!
I had sent you a Private Message back on the 8th asking if you were sure you needed a full set and not just one or two injectors but I didn't hear back from you. I'll see if I can find the set! Check for my PM since that will be a more appropriate channel for communication.
Cheers,
Don
Old Dec 17, 2020 | 03:43 PM
Eddiec's Avatar
Hi Eddiec,
Cheers,
Don
Hi Don,
Thank you for your prompt response.
I'll require 6 fuel injectors please. All existing ones have been check and requires to be replace.
please email me directly at PERSONAL CONTACT INFORMATION REMOVED FROM PUBLIC FORUM.
I'd like to have my car going so I can put it in storage for the winter
Kind regards
EddieC
Kwik Kat
General Tech Help
Feb 28, 2020 01:44 AM
new mexico
Jul 6, 2017 04:28 PM
JKo
Jul 22, 2014 12:12 AM
dc4prez
May 22, 2014 05:55 PM
Kbudd
Mar 8, 2010 07:04 AM
