drovr car around for about 2 hours today - on way home suddenly Check ENGINE light comes on - i read manual - all it says if see jag dealer :-( any Ideas what to check myself ???
Ungn
close
- Join DateJan 2016
- LocationSouthlake, TX
Liked:375 Times in 309 Posts
Most autoparts stores can read the codes for you and tell you at least what the code is. The code may not be the actual problem, but it can point in the direction of the problem.
Lady Penelope
close
- Join DateApr 2017
- LocationKansas City USA
Liked:1,397 Times in 1,096 Posts
V8 or inline inline 6 engine ?
Ungn
close
- Join DateJan 2016
When I smell gas and don't see an obvious gas leak from a fuel line, fuel injector, etc or a pre-cat exhaust leak, I always suspect O2 sensor.
Don B
close
- Join DateFeb 2014
- LocationCrossroads of America
Liked:15,276 Times in 7,257 Posts
Quote:
Hi Jaglady96,Originally Posted by Jaglady96
turns out code shows Oxygen sensor probability
I have moved your thread from the forum for the X308 to the forum for the X300, which is the Jaguar factory project code for your 1996 XJR6. Here you will find knowledgeable owners of similar cars.
If you will please post the actual diagnostic trouble code (DTC) as it appeared on the scanner, we'll be happy to help.
I'm attaching the DTC Summaries manual which gives definitions and possible causes of each code.
Cheers,
Don
