Engine light just came on? 1996 XJR
drovr car around for about 2 hours today - on way home suddenly Check ENGINE light comes on - i read manual - all it says if see jag dealer :-( any Ideas what to check myself ???
When I smell gas and don't see an obvious gas leak from a fuel line, fuel injector, etc or a pre-cat exhaust leak, I always suspect O2 sensor.
Hi Jaglady96,
I have moved your thread from the forum for the X308 to the forum for the X300, which is the Jaguar factory project code for your 1996 XJR6. Here you will find knowledgeable owners of similar cars.
If you will please post the actual diagnostic trouble code (DTC) as it appeared on the scanner, we'll be happy to help.
I'm attaching the DTC Summaries manual which gives definitions and possible causes of each code.
Cheers,
Don
Cheers,
Don
tpwild
Apr 25, 2012 09:18 PM
rosemont83
Oct 14, 2008 11:24 PM
