Engine problems.
Old May 4, 2009 | 11:58 PM
kraziegreggz's Avatar
Default Let it dry
For starters leave the hood open under the sun for a few hours at a time, and see what happens......
Old May 5, 2009 | 07:44 AM
Doug's Avatar
Red hot exhaust suggests a bad igntion misfire as unburned fuel accumulates in the cat converters.
I'd start by using WD40 or electrical contact cleaner on all the connectors to see if you can drive the wetness out. You may have to open some of the connectors up. Take a hard look at the coils, too. Maybe some water got in there as well?
No reason to think the car is a lemon.
Old May 5, 2009 | 10:51 AM
newquaymarc's Avatar
Default your engine problem
hi there
had the same problem at the weekend
i washed down my engine, and started up and running like a pig,
found the problem
on the six's the coil packs let in water to the plugs
i had 2 coils packs sitting in water, (no gaskets on them)
so i know very naughty way of doing it,, but just undone the plugs let the water run into
the cylinder, wipe down the plugs n coils pop em back in and running perfect again.
hope it helps you
cheers
Old May 11, 2009 | 08:11 AM
Jack42038's Avatar
Just so you know to watch out for it, the moisture that was down in the coils can have contributed to cracking in the bakelite casing of the coil. It is possible to repair those cracks, but they will cause a loss of power to the plug and discharge into the valve cover if left unrepaired.
Peace!
Jack
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
MrMellor
Sep 7, 2015 10:22 AM
obwoodie
Sep 3, 2015 07:45 PM
OkieTim
Sep 2, 2015 12:48 PM
