Front bumper needs adjusting on one side
Old Sep 9, 2025 | 05:01 PM
cdma's Avatar
Default Front bumper needs adjusting on one side
I was looking at my bumper and noticed that on one side, the edge of the plastic cover doesn’t line up with the fender. Is there a way to adjust that side in by about an inch? I’m assuming the previous owner had an accident, and the side that was hit sticks out more than the other which does not make sense but it does.
Old Sep 10, 2025 | 02:58 AM
Spud Maat's Avatar
i had this issue when i was repairing mine after an accident. after some fiddling around to move guard back a bit i got it pretty good.
here in AUS our bumper mounts are solid. could space them out with washers if need be but not shorten them.
i saw the US ones however have a shock absorber on them. and it appears that can be adjusted screwed in and out.
i wanted to get a set over here because they look so good.
actually allowing the bumpers to move in and out to absorb impact
Old Sep 10, 2025 | 05:21 PM
cdma's Avatar
Thanks Spud. Yes, that is what I tried, but my shocks must be bent or just faulty because it didn't do anything. Ordered some more and will give it a shot when they come in. Can't wait to drop the bumper to get to them
Old Sep 11, 2025 | 03:24 AM
Spud Maat's Avatar
I hope they are infact adjustable....
I can not confirm 100% as i do not have them.
It looks to me as tightening the nut on the back should shorten it and loosening the nut should lengthen it.
it may just adjust the dampening force tho
got any pics to show it out of alignment?
i can think of a way to potentially modify them if they are not adjustable.
now when it compresses on impact it pushes out the back.
if you were to compress it, then weld a piece of metal on you could limit how far back out it could go.
essentilly jamming in in place under slight load.
Old Sep 11, 2025 | 05:38 AM
cdma's Avatar
Here you go. Tried to make adjustments and pull it in. Nothing happen that much. I backed the nut back out and noticed that the nut backed out but the shock did not go with it. I am thinking that shock is toast
Old Sep 11, 2025 | 06:09 AM
Spud Maat's Avatar
damn that is a long way out!.
it def could be that the shock is cooked and is over extended out.
Old Sep 11, 2025 | 05:15 PM
watto700's Avatar
G'day Phil,
The only way you're going to find the cause of the misalignment is to take the bumper off the car. It is pretty easy, only two large bolts and as it is the front bumper corrosion shouldn't be an issue. Don't forget to unclip the undertray from the front wheelwell area and also the brake cooling ducts..
If the energy absorbing mounts are no longer available you could probably mail order source the fixed mounts and just replace them.
I have included a couple of pix of my front bumper when I removed it, it is an Aussie car so it has the solid mounts.
Cheers,
Jeff.
cbarr
Nov 26, 2024 12:19 PM
Daim
Feb 21, 2018 12:55 PM
Pilotman11
Feb 6, 2016 06:19 AM
Robert Mccairley
Aug 26, 2013 07:16 AM
GhostriderXKR08
Feb 21, 2011 01:42 PM
