Fuel gauge going wonky
Old Sep 25, 2021 | 06:18 PM
cdma's Avatar
Default Fuel gauge going wonky
Over the last few weeks there have been a few times that when i start my car the gauge is at empty, and i get the idiot, when i know it is full. I looked at the range and it looks correct.. I shut the car off, sit and wait a minute and start it back up and it is fine. Today I tried that and it should have read half full and it only showed a quarter but over time it slowly moved back. Could this be the sending unit and if so how do i get to it.
Old Sep 25, 2021 | 06:22 PM
Parker 7's Avatar
There was something about the ground point from memory
Old Sep 25, 2021 | 06:30 PM
Parker 7's Avatar
See page 96
jagxj1997.pdf (jagrepair.com)
Old Sep 25, 2021 | 06:33 PM
motorcarman's Avatar
TSB posted again.
Old Sep 25, 2021 | 06:39 PM
Parker 7's Avatar
The ground point is the aft most behind the battery on the right side
The circuit passes through the troublesome BT4 connector above the fuel tank in position 26 as the X color wire
it will be the one below the # 25 marked in the picure
Old Sep 25, 2021 | 08:55 PM
cdma's Avatar
TSB posted again.
wow That would be a lot of work and you almost need to do this at a gas station. I will cross my fingers and hope it is just the grounding problem. Thanks for the response though
Old Sep 25, 2021 | 10:00 PM
Parker 7's Avatar
There is a fuel tank cleaner if the wiper brush on the variable resistor has some organic growth on it
We used a Biobor in the fuel tanks on the airlines but they worked on a capacitance pricipal
I worked on the wing wiring above the # 1 engine on the aircraft ( 17119 ) in Flight 800 a week before it was blown up by a missile
The FAA never asked me about it even though my repair was in a perminate record and should have been asked in the investigation
They wanted to blame it on something other then a missile even though a lot of people saw it rise to it
Old Oct 14, 2021 | 08:42 AM
j-dogg's Avatar
Mine is doing this too, where is that connector located?
Old Oct 14, 2021 | 03:25 PM
Parker 7's Avatar
Behind the large fwd panel in the trunk
The connector is above the fuel tank
Be careful to not break the connector lock pins
Steve W
Oct 22, 2020 02:52 PM
Robbo D
Jul 26, 2020 07:10 AM
Joel1
E type ( XK-E )
Sep 11, 2019 01:44 PM
Bo Todd
Jun 23, 2018 07:23 PM
agd
Nov 9, 2016 05:09 PM
