Garage door opener failed unit?
Old Aug 21, 2021 | 04:56 PM
John Baker's Avatar
Default Garage door opener failed unit?
Hey guys, trying to program my garage door opener with zero success by using the methods posted here on my 1996 xj12. The light does not blink at all. Not when I push the buttons, not when I hold them down. Not in any ignition position or even with car running. Trying to clear the codes by pressing 1 and 4 and holding also gives zero indication of life. I took down the overhead console and the only plug going to it is plugged in. Everything else works fine like the sunroof and map lights. Could my garage door opener module be bad? Or is there something simple I'm missing?
Old Aug 21, 2021 | 08:45 PM
xalty's Avatar
it will never ever work. you need to use the x308 overhead console for anything made in the last 20 years
the guy who sells the remote fob covers on ebay knows how to do it.
Old Aug 22, 2021 | 09:51 AM
motorcarman's Avatar
Try an internet search for Rolling Code garage door openers.
Jaguar did send out a TSB for this problem.
Old Aug 22, 2021 | 08:54 PM
John Baker's Avatar
OK thank you!
Old Aug 23, 2021 | 08:50 AM
nileseh's Avatar
Default converting the x308 GDO to an x300
Yup.
If you need to replace the GDO in a X300 or X305 you can use a later X308 module after modification. The X308 module also enables rolling code receivers.
File Type: pdf
Old Aug 24, 2021 | 08:33 AM
Not ALL X308 or X100 GDO modules are 'CODE PROTECTED' or 'ROLLING CODE'.
The early ones had a RED LED to indicate NON rolling code transmitters.
The later ones were AMBER and have this feature.
Be aware of this before rummaging through a salvage yard and get the wrong one.
When I worked at the dealer we had more than a few customers that could NOT program the GDO to their house.
BRAND NEW 1997/98 Jaguar XK8 at the time had the RED indicator lamp (The 98 X308 did) and no matter how they tried, the GDO would not work in their BRAND NEW HOUSE with their BRAND NEW CAR!!
The service writer would often tell us to just order the ROLLING CODE transmitter and claim the 'faulty' NON rolling code in warranty and replace it.
I think we got 'caught' and Jaguar was NOT happy that perfectly good (but incompatible) transmitters were being replaced in warranty.
Jaguar issued a letter indicating that they reserved the right to update the car without having to 'retroactively' refit all previous models unless it was a SAFETY issue.
File Type: pdf
Old Aug 26, 2021 | 03:24 PM
John Baker's Avatar
Awesome great info guys! Should be able to fix this easily now.
Old Sep 14, 2021 | 06:29 PM
cdma's Avatar
So here is something new. I got one of the X308 console. I did do the light conversion first. After I completed that and hooked it up it worked great on my "older" rolling code garage door. It was a Chamberlin liftmaster. Now on my new liftmaster, with MyQ built in I could not get it to work. I would put the remote up to it and sometime it would sit there and blink at me but sometimes it would go like it synced up but when I pushed the yellow button on my garage door to sync up it would just blink like it was not programmed......Anyone have any ideas? Worse case at least I got one to work....oh and it is the one with the yellow light.
Old Sep 14, 2021 | 09:06 PM
nileseh's Avatar
Don't know anything about Liftmaster or MyQ.
I have lots of cars and also remotes that operate the garage doors. I found out that the Overhead Door Rolling code devices can only program 4 or 5 separate remotes, handheld or vehicle mounted. Not enough for my needs. But Overhead has a universal receiver that allows another 4 or 5 and simply replicates the push-button contacts when a signal is received. It is a Rolling Code receiver and it works with the standard vehicle transmitters, including this X300.
It's an option to stay out of the rain on occasion.
Old Sep 14, 2021 | 09:08 PM
nileseh's Avatar
Sorry, I meant the X308 rolling code transmitter.........
Old Sep 18, 2021 | 11:37 AM
John Baker's Avatar
I got one out of an XJ8 that matched my interior off ebay for 50 bucks, did the mod so the lights would work. Thanks so much!
Old Sep 18, 2021 | 05:48 PM
I have two liftmaster/chamberlain wall mounted GDOs in my shop for the 10 foot doors.
None of my XJ sedans or my 2000 XJR will sync up with them.
I have an 'older' (ten years old) ceiling mounted chamberlain 3/4 HP 'rolling-code' GDO for the 16' house door that works with all of the Jaguars,
The MyQ door openers must be incompatible with the regular 'rolling-code' GDO transmitters from years ago?
Brian XK8
Jul 6, 2016 06:36 AM
280zx-turbo
Sep 22, 2015 11:51 AM
MySType
Feb 18, 2009 08:09 AM
truckdogg4
Jan 8, 2007 10:39 PM
