Gas coming out from cap
Old Nov 17, 2011 | 07:34 PM
pan84's Avatar
Default Gas coming out from cap
Hi every one again
My next problem with jaguar is gasoline now.
Just put full gas tank of fuel and after couple miles I smell the gas. When I come back to my house and open gas tank cap, gas coming out from there, about 2 or 3 cups. When car on the sun couple hours and I open the cap, lot of air coming out. So it is normal or I have problem?
Thanks for any answer.
Old Nov 17, 2011 | 08:35 PM
Lumppy47's Avatar
Like most everything gas expands with heat.Also the tank might not be venting properly.
Old Nov 17, 2011 | 08:47 PM
pan84's Avatar
How I can check the ventilation?
Old Nov 17, 2011 | 09:43 PM
pan84's Avatar
Where I can find the vacuum diagram for emission system? I don't have any fault codes, if something like purge valve is bad "check engine" light should go on right?
Old Nov 18, 2011 | 08:24 AM
motorcarman's Avatar
Here is some info for checking your system
bob gauff
Old Nov 18, 2011 | 08:43 AM
pan84's Avatar
Its looks impossible without couple thousand dollar tool
Old Nov 18, 2011 | 12:50 PM
RJ237's Avatar
In a different thread I found jaguarclassicparts.co.uk. You will find all of the parts of the Evaporative Emmision Control System. Could the purge valve be plugged?
Old Nov 19, 2011 | 04:51 PM
pan84's Avatar
That website not work
If I have problem in the emission system light should come on?
Old Nov 19, 2011 | 08:41 PM
RJ237's Avatar
Genuine Jaguar Parts and Jaguar Accessories for Classic Jaguars
I am not as skilled as many of the experts here. Maybe this will work. I am sure someone with more experience can comment about codes and lights.
way2far
Aug 31, 2022 09:26 AM
kelliott
May 31, 2022 05:26 PM
Russ Graber
Feb 23, 2019 11:59 AM
XJsc-guy
Nov 23, 2015 01:56 PM
Xkr x100
Sep 6, 2015 08:50 AM
