hbear
Old Nov 28, 2022 | 08:17 AM
hbear's Avatar
Default hbear
i,ve got a 1996 x300.got a bulb out warning all lights working,but no main beam warning light.
Old Nov 28, 2022 | 08:59 AM
Parker 7's Avatar
The bulb out light is some current sensors in the external light module
under the car in the 4 corners there are 4 / black square 13 position connectors that can get some corrosion lowering the current
the small bulbs that are a glass envelope that has contacting wire ears can be bent out to make better contact
Incorrect bulbs even though they will light up can also draw too low a current to get your bulb out light
In 95 or 96 after a certain VIN # there is only one external light module in the trunk
Your headlights are the same but located separate current sensors,as the sensors are not in the external light module
Old Nov 28, 2022 | 09:30 AM
Nobeel Masri's Avatar
I had the warning light come on when one of the dual filament rear light bulbs failed.
It might be worth checking that all of the bulbs don't have any burnt out filaments, maybe starting at the rear.
Old Nov 28, 2022 | 09:53 AM
hbear's Avatar
Default hbear
thanyou
Old Nov 28, 2022 | 09:56 PM
Don B's Avatar
Hi hbear,
Welcome to the Jaguar Forums! It's great to have you with us.
Have you checked your license plate lamps, reverse lamps, and all side marker lamps? Those are easy to miss.
As routine maintenance, it is worthwhile to remove all the tail lamp bulbs, clean the bulb bases, and clean the sockets and center terminals and re-tension the center terminals. As Parker mentioned, added resistance due ot corrosion can cause the lamp module to determine that a bulb filament is open.
Cheers,
Don
Old Dec 1, 2022 | 07:30 AM
hbear's Avatar
cheers dodgy bulb now 👍
Old Dec 1, 2022 | 07:35 AM
hbear's Avatar
Default hbear
my heater blows warm air c an.not change temp or direction. have changed control and heater ecu.no difference. where next x300 1996
Old Dec 1, 2022 | 07:57 AM
As you have already checked the Control Module (item 2), a likely cause of not being able to change airflow direction is failed Servo Motors (items 3 and 4):
These operate flaps to direct and blend the air.
Old Dec 1, 2022 | 10:56 AM
Parker 7's Avatar
There is a front control panel bite test on page 110 of the following doc
T703 BOOK (jagrepair.com)
Your codes are here
14-10 (jagrepair.com)
You can manually drive the trim motors with a 9 volt battery in both directions and you van hear them respond ( this proves the motors work but not the follow up motor position sensors )
Old Dec 1, 2022 | 12:27 PM
Parker 7's Avatar
Does the A/C blow cool air ?
Never any truly heated air ?
Does the turning of the blue to red control wheel on the center vent change anything ?
A common item is the cabin temp sensor that gets lent in it and can be cleaned but don't use a spray solvent
this sensor is below the steering column with the 1 inch square vent on the kicker panel
mattfirevai
XJ XJ12 ( X305 )
May 30, 2021 11:57 AM
orangeblossom
Jan 2, 2020 06:41 AM
daddylogan
XJ40 ( XJ81 )
Feb 12, 2016 10:59 PM
anziobridgehead
General Tech Help
Jun 15, 2013 10:57 AM
