How to open the trunk(boot) lid manually
Old Jun 11, 2020 | 02:56 PM
mcart5's Avatar
Default How to open the trunk(boot) lid manually
Hi All, I have a 1995 X300 VDP in which I had pulled the battery to do some electrical work (clock) and had placed a piece of board in the trunk(boot) to keep it from closing. Unfortunately someone dislodged my board and I can't get into the trunk. Is there a manual cable inside the cabin to open the lid.
THX
Keith
Mcart5
Old Jun 11, 2020 | 03:08 PM
motorcarman's Avatar
Why not just use the KEY?
Old Jun 11, 2020 | 04:19 PM
b1mcp's Avatar
As Bob says.
But if your key doesn't work (many are seized through lack of use), connect a battery with jump leads to one of the fuse box main power leads and a good ground point in the engine bay. That should do to power up the locks.
Old Jun 12, 2020 | 11:57 AM
xalty's Avatar
If your key doesn’t work, just drill a hole. When you get it open make sure the nuts securing the megafuses are tight.
Old Jun 12, 2020 | 01:38 PM
mcart5's Avatar
Hi again, yes the key doesn't work(it hasn't been used in years). I don't think I going to drill through the back trunk to unlatch, I will try to power-up the relay first.
THX
mcart5
Old Jun 13, 2020 | 03:05 PM
aholbro1's Avatar
You don't need to drill. If you can't power it up, remove the number plate, and you'll find a couple of body-colored tapes over the lower number plate holes. There are threads here with pics and instructions how you can unlatch the boot through one of those existing holes. Do a search, you'll find you're not the first member to fail to utilize your key on the boot once/mo or so.....
XtypeHI
Jan 2, 2019 07:06 PM
55jag05
29
Mar 28, 2014 02:46 PM
esloser
May 16, 2013 05:36 PM
hdfx81
Mar 11, 2013 02:27 AM
kats98
General Tech Help
Apr 26, 2009 07:15 PM
