Manual conversion
Old Apr 29, 2023 | 09:46 AM
Generalbaxter's Avatar
Default Manual conversion
so iv got a xjr6 in my landrover, bolted to a zf4hp24 gearbox, (so its already got the zf adapter plate and bits)
but im looking at a manual conversion, but the getrag 290 gearbox seems really hard to find and when you do, they are really expensive and require a rebuild,
Is there any other gearbox that bolts onto these something more modern maybe a 6 speed?
Old Apr 29, 2023 | 10:36 AM
bjarnetv's Avatar
I haven't heard of anyone using anything else since the 290 used to be plentiful enough, but now it seems the market has dried up completely.
I was thinking the new Tremec TKX might be a good option - there are bellhousings available for it that fit the 6L V12, so it should work with the the AJ16S as well since it shares the 4l80e with the V12.
you would need a custom propshaft made though.
Old Apr 29, 2023 | 10:57 AM
Parker 7's Avatar
NV3500 was the licensed built version of the Getreg 290 in the US
Bolt patterns may have been tailored for the engine matching in the US market
New Venture Gear 3500 transmission - Wikipedia
Old Apr 29, 2023 | 10:58 AM
if its helps, i should of said im in the uk
Old Apr 29, 2023 | 11:03 AM
bjarnetv's Avatar
an old quote i found when googling the 3500
Getrag 290 is the transmission variant you're after - and you need only the Jaguar one. By then, it had an integral bellhousing and none of the other variants will fit. The BMW variant is a different bellhousing pattern and the engine is installed on an angle. The others (GM/NV, etc) are all for pick-up trucks and the shifter comes out the top of the box - you cannot move it.
Old Apr 29, 2023 | 11:09 AM
Parker 7's Avatar
There was a resent manual conversion done in the US for a AJ16 supercharged that covers the details.
XJR6-AJ16S knowledge - Jaguar Forums - Jaguar Enthusiasts Forum
Old Apr 29, 2023 | 11:12 AM
looking up link
yes iv read it, as stated the getrag290, is an externally rare box here in the uk now, there is one on ebay 4 hour drive from me in bits, casing and all the rest is loose in a rusty box for approx $500 lol
Old Apr 29, 2023 | 11:21 AM
Parker 7's Avatar
There was a supercharged X300 outside London on E - bay that the owner was parting out that may have the Getreg 290 in it
I'm not sure if it was offered by Jaguar as a factory built manual transmission version for the British Market
Old Apr 29, 2023 | 11:29 AM
iv just had a look cant find it
Old Apr 29, 2023 | 11:43 AM
Parker 7's Avatar
I gave the link to Andy Stoddard a few months ago who was on the engine design teem at Jaguar back then
I'll see if I can retrieve it
It was in the northeast corner outside London
Old Apr 29, 2023 | 12:07 PM
Parker 7's Avatar
I can't retrieve sent private message history sent to Andy on this forum from my side.
He would have the received message on his history and may run across this tread and maybe pic up on it
I sent the E - bay offering to him as he has 2 supercharged examples as a potential part resource if he has some things in the works
His ID is " XJREngineer "
Old Apr 29, 2023 | 01:18 PM
SC Chinchilla's Avatar
I've often thought these cars would really rock with a manual, although the ergonomics are a bit funky in the factory shifter spot.
Old Apr 29, 2023 | 06:34 PM
Parker 7's Avatar
Andy has modified the AJ16 supercharger engine ECU to handle the manual.transmission
So work has been done in cracking the code
Old Apr 30, 2023 | 03:50 AM
im already running a standalone, MAXXECU with a compushift standalone gearbox controller,
Old Apr 30, 2023 | 10:29 AM
Parker 7's Avatar
This is a normally aspirated 4.0 liter with Andy's bracket for ignition 5 degree advance
Dukejag
Apr 29, 2023 12:13 PM
wayneb1408
General Tech Help
Dec 31, 2015 12:05 PM
DevonDavid
Apr 7, 2013 02:40 AM
stefon57
Oct 8, 2011 11:36 AM
Sean B
Oct 4, 2011 03:42 PM
