More Electrical Gremlins
Old Mar 29, 2024 | 03:31 PM
Big Amar's Avatar
Default More Electrical Gremlins
Evening all, I recently been working on the Audio system on my Daimler Six 1994 and after getting all that working now for some unknown reason the Dashboard lights to not switch of when taking the ignition key out and sometimes the steering lock does not come on. I have also noticed that the Cigarette lighter socket has also stopped working ?
Any ideas ?
PS the Audio system works a treat LOL
Old Mar 29, 2024 | 03:49 PM
Parker 7's Avatar
When pulling the key out it makes the pin 4 to pin 5 which is a car frame ground
This linier switch can stick
The pin 5 to car frame ground could have been disturbed somewhere behind the dash
To test this pin 4 to 5 , does the seat and steering column move on key removal ? the large rotary knob on the steering column must be in auto
Old Mar 29, 2024 | 03:57 PM
Big Amar's Avatar
I will test this in the Morning. When you say the plug may have been disturbed is this plug behind the radio?
Old Mar 29, 2024 | 05:59 PM
Parker 7's Avatar
The functional test is easiest and first
The most probable is the ground stud for wire on pin 5 , you dash lights may share this ground stud
The ignition switch connector in the pic is when removing the small curved panel under the steering column , column / car's left side
5 wires so easy to identify
The pic is the switch side of the connector that the switch does not need to be removed
The car side of the connector is mounted on a dash bracket and can be lifted straight up to remove to have the work out at you
The pin 5 wire color is common Black
Should have as close to 0 resistance to car frame ground
Look for corrosion in the connector ( spilled fluids )
Old Mar 29, 2024 | 06:08 PM
Parker 7's Avatar
" steering lock does not come on "
is the key lock actuator and relay controlled by not in park switch
You can slightly move the shift lever out of the park gate and a finger on the key barrel should feel a click
See page 89
jagrepair.com/images/AutoRepairPhotos/jagxj1996.pdf
Old Mar 30, 2024 | 02:53 PM
Big Amar's Avatar
Hello,
So the steering lock is all working
The Electric string coloum works and on auto setting retracts away
But now the issue is the Illumination still stays on and
The Wiper will not stop when I press it down for intermittent use and when I dod manage to get it to park it parks in random places
90's car electrics enough to fry your head.
Old Mar 30, 2024 | 05:09 PM
Parker 7's Avatar
Wiper switch stalk has a history of the wires coming off , resolder
Easier thing is the 2 wiper relays swap with one other then a wiper
Old Mar 30, 2024 | 05:16 PM
Big Amar's Avatar
Hello Sir,
Is it worth me getting this to solve Illumination on dashboard dials staying on ?>
https://www.ebay.co.uk/itm/303981473...&ul_noapp=true
Old Mar 30, 2024 | 05:51 PM
Parker 7's Avatar
Hold off as there may be some free things to check
Researching
There is a full bright dash lights selection on the small knob on the steering column
Old Mar 30, 2024 | 05:52 PM
Big Amar's Avatar
Thank you for your assistance it is greatly appreciated
Old Mar 30, 2024 | 10:05 PM
Parker 7's Avatar
Large # 5 right relay is not a swapping option so best leave that one alone
It is the 2nd power for the engine ECU used at all times so you don't want to induce a engine stall
There has been reports from reading of the stalk switch wiring as it goes through the steering column chafing and damaged
Old Apr 6, 2024 | 08:41 AM
Big Amar's Avatar
Ok Guys,
I am working my way through the Gremlins only a few left to sort:
  1. Wiper does not park in the same spot - Random areas and wipers do not work as they should.
  2. The bulb warning light comes on as soon as I put the side lights on yet all bulbs are working. All front bulbs have been replaced
  3. I have ordered a replacement illumination control module which I hope will solve the dashboard illumination staying on - For the time being, I just unplugged the dimmer switch which seemed to prevent the lights from staying on
  4. Now the anti-lock light comes on once the vehicle goes above 15 mph - I have checked the resistance on the rear ABS sensors and they seem to be all working fine. I have also removed, cleaned, and refitted the multi-pin plug under the ABS pump.
Any ideas or help is greatly appreciated.
Old Apr 6, 2024 | 05:41 PM
Parker 7's Avatar
Look for code C19 something
Do not remove wheel sensors yet , fragile plastic body and expensive replacement part
12.5 mph is the trigger point along with 2 or 3 drive cycles for dash warning
There is a wiper park switch inside the gearbox aft of the motor , size of the red button throw and polarity is important
Easier to ensure the articulating motion arms inside the large rectangular box is lubed
Old Apr 7, 2024 | 03:46 AM
V126man's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
There is a known issue with dry joints on the power connection inside the ABS module which causes the ABS light to come on.
See item #6 in this post which has a pdf of the repair method attached. it is not necessary to disconnect the hydraulic brake lines as the electronic module can be removed from the hydraulics by levering the ABS unit upwards and removing the two Torx T20 bolts at the bottom that secure the electronic module. Not easy to access but better than removing the brake lines.
https://www.jaguarforums.com/forum/x...though-144318/
Old Apr 7, 2024 | 05:44 AM
Big Amar's Avatar
Thank you all for the help and advice.
Old Apr 7, 2024 | 07:56 AM
Parker 7's Avatar
Although there is a precaution to the wheel sensors removal it is the first step to resolving ABS issues without a code reader
In the marked different color 4 pairs of sensor wires they will read 1300 ohms as a basic meter reading
If you spin the wheels in the correct direction , they will read about 1 volt AC
The brake switch is involved also , actually 2 switches in 1 package with 1 dedicated to the brake lights
This will be pin 20 on the ABS connector
In removing the sensors to clean the face of the sensor ( collects grease and metal debris interfering with the signal ) you can push out from the inside of the hub to remove them after soaking with some penetrate spray
If you pry too hard on the attaching mount ears from the outside it can seperate leaving the metal sensor cap and sensor in the hole
If you need a new sensor there are 2 different sensor group of 4 part #s during X300 production
A left sensor will not work on a right
Howell
Oct 24, 2023 08:47 AM
HauntedMyst
Oct 17, 2021 10:19 PM
Blues boy
Jun 14, 2021 04:30 PM
GaryinOregon
Apr 21, 2010 02:41 AM
