Need help identifiing part above A/C
Old Nov 15, 2017 | 12:27 PM
BobinVA's Avatar
Default Need help identifiing part above A/C
Hello all, new to the Forum and would like help identifying this part above my AC compressor.
1995 VDP 4.0 6 cyl. it has an adjustment on it and I have a slight leak. Thanks in advance, Bob
Old Nov 15, 2017 | 03:01 PM
Lady Penelope's Avatar
A . If it is the part with the plastic window it is the cam position sensor that has an O-ring in it as it is inserted into the block .
B . If it is the one cover above that device it is a cover to the cam tensioner adjustment
Attached Thumbnails Need help identifiing part above A/C-partinquestion_27d57ac4a74cb91af8fb57c663a196ea8dc07f7a.jpg
Old Nov 15, 2017 | 03:53 PM
BobinVA's Avatar
That helps a lot, I am not a Jag motor guy but have solved most of my issues.
My real concern is a new oil drop coming from the unit the cam position sensor is mounted too.
In the picture, look at the stamped number on the housing, then zoom in close.
It looks to me that it had been removed/repaired as you can see what looks like Permatex instead of a gasket.
I replaced the valve cover gasket in the spring and have had no leaks till now.
Thanks for the reply Lady P. any additional thoughts would be appreciated.
BobinVa
Old Nov 15, 2017 | 04:13 PM
O.K. My seal is not squeezing out as yours where you have the letter stamp . I believe what is behind the stamp is the oil pump , but I do know what is behind that on the same shaft is the power steering pump .
Old Nov 15, 2017 | 04:21 PM
BobinVA's Avatar
Excellent, this will put me on the right path to do more research.
Thank you,
BobinVa
Old Nov 15, 2017 | 04:35 PM
Here is a link below : The seal in question is on the front face of item # 5 , the P. S . pump adapter
https://www.jaguarforums.com/forum/g...teering-94434/
Attached Thumbnails Need help identifiing part above A/C-x300-power-steering-pump.jpg
Old Nov 15, 2017 | 04:47 PM
Motorcarman ( Bob Gauff ) has listed some pdf's for the subject area in his response on another tread . On document 10 - 04 , illustration 2 looks like a recessed flange I painted in red and green is where a seal goes with the yellow unsealed mating face where you have the tube Permatex product oozing out .
https://www.jaguarforums.com/forum/x...cement-150073/
Old Nov 15, 2017 | 05:07 PM
Attached Thumbnails Need help identifiing part above A/C-x300-power-stearing-pump-adaptor-untitled.png
Old Nov 15, 2017 | 05:55 PM
BobinVA's Avatar
That helps even more. Thanks again, BobinVa
