no power......1995 XJ6
Guest
Posts: n/a
OK here goes. After a warm up of about 5 min. I have no power. In other words when you give it gas it won't give you that extra power. Sputters and revsstay low. Idles fine, well ok. Have changed MAF sensor, new plugs, removed 1st set of O2 sensors to relive pressure in cat convertor to see if cat was plugged, no change but still not convinced I don't have a plugged convertor....there are 3 right? There seemed to be enough volume coming out of the tail pipes. Engine light does not come on but does work. It would seem I get a good reading from MAF but info coming out of ECM is distorted (computer). The fuel pressure was ok, was within limits. Disconnected coolant temp sensor and no change plus engine light didn't come on. Enough for now......any ideas???
well first the car only has one massive one piece cat. and i wud look inside the tank.. had plenty that the hose from the pump comes off or is only half on.. and bleeds into the tank..
you can also check crank sensor signal
good reading should be about 1.2 volt A/C while cranking engine
i"ll check and verify reading in a few
check when cold and then recheck when fault occurs
Guest
Posts: n/a
Thanks for the replies.....I had a no start problem once and it was the crank sensor. Is it true that a faulty crank sensor could cause this loss of power as well. The interesting part is that when the engine is cold I can accelerate no problem......however after warm up the no power situation occurs.
baskervillema
Oct 1, 2015 06:43 PM
