oil drain plug washer/gasket
Old Jun 9, 2021 | 01:05 PM
Todd Wiens's Avatar
Default oil drain plug washer/gasket
Is it necessary to replace the oil pan drain plug washer/gasket every time you change the oil?
They are not easy to find locally.
Old Jun 9, 2021 | 02:17 PM
motorcarman's Avatar
If it looks to be in good shape (not distorted) you can use them a few times if you don't get crazy with torque upon tightening.
The ones with the steel outer ring with rubber insert seem to last a few oil changes.
Aluminum or copper can get crushed after a few uses. (or one big overtighten!!)
Old Jun 9, 2021 | 02:19 PM
Todd Wiens's Avatar
Thanks!
Do you know the torque setting for the drain plug?
Old Jun 10, 2021 | 04:40 AM
someguywithajag's Avatar
Look up "dowty washers" on Amazon. I believe the size on the drain plug is M18 (not sure, measure the diameter to get the correct size). You can buy them in bulk at economical prices. Or try any place that sells hydraulic equipment; they should have them too
Old Jun 10, 2021 | 08:40 AM
Originally Posted by Todd Wiens
Thanks!
Never used a torque wrench on any sump plug on any car in my life.
Nice and firm, with a dose of Common Sense has served me well.
Washers, whatever I can source, usually copper, in packs of 20. Using the above method, about 4 uses, with a turn over at the 3rd use, thus using the other side. The V12's were the worst, usually due to Rock Ape previous people.
Dowty entered a bit, but the later stuff has an o/ring, PITA.
Old Jun 10, 2021 | 09:01 AM
The oil drain plug is M20 x 2.5mm.
'SNUG' is good.
Stripped Threads = BAD.
Old Dec 24, 2022 | 11:52 AM
labcoatguy's Avatar
Figured I'd rather bump an established thread than needlessly start a new one. I just bought a 10-pack of these drain plug washers for less than $5 shipped from https://www.anhosefittings.com/dowty...bsp-13-16.html
Old Dec 24, 2022 | 04:40 PM
Parker 7's Avatar
See page 11 of the doc below
Drain plug to oil pan 64.8 to 79.2 Nm
573 to 701 inch pounds which is quite high
As Motorcar man says snug is good over thight is bad , mine took 8 days to get mine off from the previous owner not wanting to damage things in the process
Snug and keep a eye on it after a engine run warming things up
We always did this when tampering with the engine oil systems on aircraft and plenty of accidents have accured when not verified
CCM911
XJ40 ( XJ81 )
Feb 25, 2021 05:32 AM
rsq911
Mar 13, 2016 05:30 AM
dstary
Jul 3, 2014 07:43 AM
mrcjr24
Jan 17, 2009 10:27 AM
Trooperbsb
Jun 12, 2008 08:29 PM
