Power window issue from X300
Old 10-18-2015, 06:43 PM
RFXJ12's Avatar
Default Power window issue from X300
Hoping to solve a problem with 1997 XJ6. Drivers power window doesn't work.
All other windows worked from master control switch so swapped out master switch with a another used one (can not verify if the replacement is OK).
Drivers window would go up with new switch but not down.
In the process of going back and forth with switches, the control of the left rear window stopped as well.
Now neither drivers front or left rear will work, up or down, with master switch.
Both motors check out OK.
"All (global) closed" feature with key in door only closes the functioning windows (the two passenger windows and sunroof).
Tried hard reset with battery disconnected for 15 mins. No luck.
How can I verify is master control switch is functioning properly or does this problem seem to be something else?
Old 10-19-2015, 01:08 AM
JagV8's Avatar
Received 4,488 Likes on 3,905 Posts
Hang on for a mod to move your post to the right forum.
Old 10-19-2015, 02:15 AM
GGG is offline
Received 16,821 Likes on 12,177 Posts
Originally Posted by rfxj6
Hoping to solve a problem with 97 XJ6. Drivers power window doesn't work. ............
I've moved your question from General Tech Help to X300 forum. Members here with the same model will be able to help.
Old 10-19-2015, 03:55 PM
RFXJ12's Avatar
Previous owner had the starter jumped to a push button to start the car because the key, when turned to the start position, will not engage the starter. Any ideas on this problem? Would love to fix it and be able to start with the key. Have been searching the threads but can't find solution. Which relay can I swap to check starting relay? Assuming previous owned tried this before adding starting button but you never know.
Only other problem is driver's side power windows don't work. Fuses good and window motors work when jumped with hot wire. Tried a different master switch and driver's window, then would go down but not up then stopped any function after a while and left rear then stopped working. Now I can hear clicking only for window down in front and window up and down in rear.
Not sure if starter and windows are a related problem??
Thanks again
Old 10-25-2015, 07:36 PM
I'd say you need to check the wire harness that goes through the corrugated rubber boot at the door jamb. Likely wires have broken in there due to years of flexing as the door opens and closes.
Cheers,
RFXJ12 (11-08-2015)
Old 10-26-2015, 01:58 AM
sounds silly but try a hard reboot
Old 10-26-2015, 07:25 AM
aholbro1's Avatar
Received 1,642 Likes on 1,068 Posts
Cheers,
So far, my X300 has been solid, but I've had that problem on the 05 S-Type. Wasn't fun.
https://www.jaguarforums.com/forum/s...allenge-98225/
The window functions were intermittent for a week or two before they quit entirely....sort of like you are experiencing.
RFXJ12 (11-08-2015)
Old 10-26-2015, 08:01 AM
RFXJ12's Avatar
Tried the hard boot (disconnected battery for 15 mins). no change.
Changed out the body control module and no change either....
Old 11-08-2015, 10:28 AM
RFXJ12's Avatar
Problem solved. Drivers door wiring harness was bad.
Now having trouble getting the large plug that connects the door lock through the hole in door for the harness. Do I have to pull all the pins to get this plug to pass through or is there another trick to it. Any experience with this would be helpful.
Old 11-08-2015, 02:11 PM
b1mcp's Avatar
From memory, the trick is to disconnect it at the other end (inside the car) as the plug is smaller there, then pull it back and out through the door. (It's a few years since I've done this so hope I remember correctly).
RFXJ12 (11-09-2015)
xjrjag
12-06-2015 03:52 PM
spanky
10-18-2015 02:42 PM
doc
10-13-2015 09:16 PM
jdzubas
10-04-2015 09:14 AM
unicorn
09-23-2015 02:59 PM
Quick Reply: Power window issue from X300
