Remote not working
Old Jan 13, 2010 | 07:50 AM
biffta's Avatar
Default Remote not working
The remote for my 1995 X300 has packed up, however some time ago I obtained another one from eBay. This is in excellent condition, however one minor problem being that it doesn't work with my car! I have tried the reprogramming procedure (valet switch etc) that I have successfully used on the now u/s remote a few times previously, but I can't get this new one to work at all. I am now suspecting that the reprogramming procedure is only for the correct remote for the individual car and that a different remote requires reprogramming at a dealer. Am I correct?
Any advice most welcome.
Thanks.
Edit. I have now read elsewhere on this forum that the remotes had different frequencies for the '95 & '97 models. Can anyone confirm this as it may explain that whatever I do I will never be able to reprogram this other remote I have?
Old Jan 13, 2010 | 10:35 AM
ken@britishparts.com's Avatar
Some how the forum ate my response. Check on the back of the unit (if I remember correctly) to see the frequency of the two remotes. Either 315mhz 433mhz.
Old Jan 13, 2010 | 06:54 PM
atann's Avatar
O'dear I have just bought one of of Ebay for my 1996 X300. Does anybody know what the frequency is for my car? It is arriving tomorrow I just hope that it will pair to my car.
Old Jan 14, 2010 | 12:12 AM
atann's Avatar
Another question, what frequency do the remotes from the X308's use?
There are loads of these on Ebay, I wonder if you can programme these to work with an X300?
Old Jan 14, 2010 | 03:53 AM
biffta's Avatar
Thanks Ken, but there is nothing written on the back of either of the remotes. It's just plain black. Prizing off the front cover however reveals lettering and numbers. For example, one says:- "JX300.03-10.01-
0 Teil
> PAS -6F30<
Linse
>PC< "
Anything from that codebeakers?
Old Jan 14, 2010 | 09:06 AM
I'm no help there. I don't know what those numbers are. The X308 we don't deal with the fobs.
Old Jan 14, 2010 | 09:18 AM
biffta's Avatar
Nevertheless Ken, thanks for the response.
Old Jan 14, 2010 | 09:32 AM
biffta's Avatar
Well I think I've solved the 'what frequency' question!
Removing the plastic cover of the remote, printed onto the printed circuit I have found the following:-
FM433.000 - 40.0001 - 11
I assume this refers to the FM frequency being 433. Problem is, this is the same on both remotes indicating they both operate on the 433 FM frequency. One used to work however and the newer 'good' one doesn't and will not successfully re-program either. So unless there is another difference between the 2, I don't know why it won't work , nor re-program like the old one did if they both operate on the same frequency!
Old Jan 14, 2010 | 10:17 AM
Now that's a bummer. Where to go next? I'm just guessing here, but you could be looking at the security ECU. They should program just the same.
Old Jan 14, 2010 | 06:16 PM
panchostatus's Avatar
I got lucky and snatched a remote out of a salvage yard and it worked perfectly!
but, no, there is no other difference to my knowledge other than the frequencies.
battery maybe? or perhaps program it into a different slot for memory, you know how it gives you the option to program separate remotes, maybe that has something to do with it?
When I did mine I just followed the procedure and the remote mated with the car on the first try.
Old Jan 15, 2010 | 06:00 AM
biffta's Avatar
Thanks Pancho & Ken. Like I've said, on occasions I used to have to reproram my old remote and the procedure always worked fine. With this new one however, it won't program. So I'm stuck for a solution, but will try what you suggest Pancho.
Thanks again.
Old Jan 17, 2010 | 01:54 AM
atann's Avatar
I have the same problem with a x300 remote I bought off of Ebay. My car will not even go into learning mode, is this because I have a problem with my boot not being recognized as being open on the dash warning light. I can't open with the growler either I have to use the key.
Old Jan 17, 2010 | 03:41 AM
biffta's Avatar
Hi atann, re' your boot open light, when you switch on the ignition and all the dash lights come on, does this one? Of course if your boot is closed at this point the light will go out with most of the others after a few seconds, but it should come on at the beginning. Next, certainly in my case the light only comes on when you open the boot and the engine/ignition are on. If the ignition is off then it doesn't.
Finally re' the key opening the boot, in my case when the doors are unlocked I can only open the boot either with the dash switch or by pressing the 'growler'. For some reason, the key doesn't open it! Think your problem (and/or mine?) may be something to do with valet switch, but don't really know. Think I should set aside an hour to try to understand the handbook on this!
Old Jan 17, 2010 | 10:31 AM
atann's Avatar
The boot open light comes on when I turn the ignition on, but goes out even when the boot is open.
Old Jan 21, 2010 | 08:46 AM
sounds like the humdinger that switches the thing is out.
kidding,
theres a switch that recognizes when the trunk is closed/open, you've probably got damaged wires or loose perhaps, causing a loss of signal from the switch, and that may be impeding your progress as far as going into learning mode.
Old Jan 23, 2010 | 03:45 AM
biffta's Avatar
kidding,
Great 'Pancho', but where is the switch located??
Forcedair1
Sep 8, 2025 01:57 PM
Bcrary3
Sep 12, 2021 05:41 AM
mbergen
Oct 23, 2019 10:26 PM
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
philwarner
Sep 5, 2015 10:05 AM
