Which spark plugs should I use for XJ6 X300?
Old Aug 13, 2014 | 09:46 AM
juha_teuvonnen's Avatar
Default Which spark plugs should I use for XJ6 X300?
It looks like R9YCC are no longer available, only R9YC. If I have to go with something other than what is recommended, I might as well look at something like NGK. Rumor has it, X300 is sensitive to spark plug resistance. Please feel free to share the plugs that you had good luck with.
Also, are R12YC's only for supercharged cars? Any advantage to fitting those.
Old Aug 13, 2014 | 10:59 PM
jvitez's Avatar
Here's the information I saved combining a TSB with a previous post on this topic:
__________________________________________________ _____________
05.1-07
Date
2-95
Amended 12/98
Model 1995-97 MY
Sedan (4.0l) Range
VIN 720001-812255
Spark plugs-AJ16 Engine-
Change in specificcation
ISSUE:
The spark plug specification is updated on all AJ16 (4.0L) Sedan Range vehicles to include supercharged engines.
Hotter spark plugs (part number EBC 8143) were installed on supercharged engines in production from 1997 MY.
ACTION:
Use the following spark plugs as service replacements in all AJ16 engines:
ENGINE PART NUMBER PLUG GAP TORQUE
AJ16 (4.0l) EBC 8143 0.9 mm (.035 in) 22-28 Nm (17-20 lb f
EBC 8143 = Champion RC12YC
I just changed from NGK to these exact Champions. Works perfectly, and they're inexpensive.
Note the word "ALL" in the TSB. So for all AJ16 engines, use Champion RC12YC plugs.
Old Aug 14, 2014 | 08:22 AM
motorcarman's Avatar
I use regular Champion RC12YC on the X300 and RC9YC on the XJ40.
Been doing it for years and never had an issue.
bob gauff
Old Aug 14, 2014 | 10:23 AM
Thanks for your help, I appreciate it!
Old Aug 15, 2014 | 03:38 PM
theJPster's Avatar
Does this also apply to the 3.2?
Old Apr 2, 2018 | 06:10 PM
xjfourty's Avatar
seems like there re at last 2 versions, one nickel and the other copper.
Would this one be okay sold on Amazon ?
Amazon Amazon
Old Apr 2, 2018 | 06:40 PM
Lady Penelope's Avatar
There is a TSB on the 9s and 12s to be used , one for the N/A and the other for the S/C x300 series relating to the heat range below :
http://www.jagrepair.com/images/TSB/...6%20Engine.pdf
Any one have any experience or technical opinions on the 3 gap plugs ? Someone seems to have resolved his idle issue with them or if it may have been placing the O2 sensors connections correctly . Are the 3 prong a gimmick ?
Old Apr 3, 2018 | 12:01 AM
al_roethlisberger's Avatar
*shrug* .... unscientifically, my observations in various reading hadn't been favorable for these multi prong/ground plugs.
Some good overall info for our plugs:
https://www.jaguarforums.com/forum/x...stions-178062/
...and:
https://www.jaguarforums.com/forum/x...-plugs-121820/
The Champion RC12YC plugs are about $2 at any auto parts store or even Walmart, so it's hard for me to get too excited about putting a lot of additional research into spark plug choice. What's really humorous is that the RC12YC is normally found in the "garden tractor" section of the store, not automotive!
I just change them every year, especially since it is so easy to do on the AJ16
Old Apr 3, 2018 | 12:17 AM
xjfourty's Avatar
so these one right ?
Welsh Enterprises, Inc - Jaguar Service Items X300 Parts - Spark Plug
Old Apr 3, 2018 | 12:56 AM
Originally Posted by xjfourty
I *guess* so, as they don't say which Champion they are, but they are probably correct if they are being sold as a genuine Jaguar part. Not a bad price BTW.
But I just get mine from Autozone or Walmart
Old Apr 3, 2018 | 09:26 PM
Don B's Avatar
https://www.amazon.com/Champion-RC12.../dp/B000CFME2A
Hi xjfourty,
Assuming you are inquiring about spark plugs for an X300 with the AJ16 engine, the Champion RC12YC plugs are $1.36 each at Rock Auto, plus shipping, but as Al says, you can find them locally for low prices, and the general consensus is that they are the best plug for an AJ16 and plenty of problems have been reported by owners who tried other plugs.
If you are asking about a different Jaguar model and engine, that will make a difference in the plug you should use.
Cheers,
Don
Old Apr 3, 2018 | 09:31 PM
Don B's Avatar
I haven't tried the 3-electrode plugs, but back in the '90s I tried the Bosch 4-electrode plugs in our '88 XJ40, and if anything, I felt the engine was slightly less responsive than with the stock Champions. This may have been my imagination, because based on the reports of others, I had expected some discernible improvement in engine performance but didn't notice any. Around that time, there were reports of the Bosch plugs having issues with the platinum tips falling off of their electrodes and rattling around in combustion chambers, so at the next oil change I switched back to Champions and never regretted it.
Cheers,
Don
Old Apr 4, 2018 | 12:36 AM
xjfourty's Avatar
yes X300 AJ16 engine.
I sold my series III one month ago...
Originally Posted by Don B
Hi xjfourty,
Cheers,
Don
Old Apr 5, 2018 | 04:37 PM
jacklynthejag's Avatar
Adding to Lady P. comments I had bought the recommended spark plug and my car ran like $#!+. I tried 3 different branded spark plug, made sure they were correctly gapped with no luck.. I purchased the 3 prong plugs and ran beautifully. Now my problem may be unique, however the O2 sensor issue was later down the road when I cleaned them and connected them to wrong harness. Anyways I plan on trying different plugs later down the road and see if there is a difference.
Old Apr 6, 2018 | 09:19 AM
You can try 'OXYGEN SENSOR ORIENTATION' with WDS or IDS to sort out the correct bank orientation.
bob
Old Apr 7, 2018 | 12:52 PM
xjfourty's Avatar
so if I understand well I have to space the gap exactly 0.9mm is it correct ?
are they sold with already the correct gap space ?
cissdm
May 3, 2016 06:02 AM
explorer364
Sep 14, 2015 07:43 PM
Pristine97XK8Convertible
Sep 10, 2015 09:24 AM
mrplow58
Sep 9, 2015 11:27 AM
Bowman
Sep 3, 2015 03:17 PM
