trans. fluid
Old May 23, 2008 | 10:57 AM
Jaybo242000's Avatar
Default trans. fluid
Hey folks-
Quick question if you don't mind, what transmission fluid would you recommend for a fluid replacement in my 1996 xj6 4.0litre. I have about 107k miles on it, I was thinking about adding theLucas transmission additive to the fluid as well, has anyone used this before, is it safe for this transmission? I have used the Lucas trans. before, I just wondered if anyone has had experience with thisadditive in our transmissions. Thanks guys, I appreciate it.
-James
Old Nov 21, 2008 | 03:07 PM
panchostatus's Avatar
Default RE: trans. fluid
I just did a transmission service on my '95 XJR, and i used the lucas additive, but make sure you know how many quarts you need, because the lucas additive makes it impossible to get an accurate reading on the dipstick. I also have a '96 XJ6 and it's been 4 qts every time. As far as fluid type I've always used Castrol Dexron VI.
Old Nov 27, 2008 | 08:59 PM
oldmots's Avatar
Use brand name Dexron III fluid. I never use any additive in the trans fluid, too risky.
Old Dec 3, 2008 | 01:41 PM
4running's Avatar
Does the torque converter have a drain on these cars?
Old Dec 3, 2008 | 01:56 PM
Brutal's Avatar
no and i use mobil1 synthetic atf, exceeds all dexrons
Old Dec 6, 2008 | 04:50 PM
Doug's Avatar
The Lucas additive does work if you want to nurse a tired transmission along. No need to use it on a healthy trans, though.
Old Dec 6, 2008 | 04:54 PM
Doug's Avatar
ORIGINAL: panchostatus
You probably already know this, but just in case......
To get an accurate reading with the 4L80E you gotta drive it till its really hot....a good 15 miles or so.
And top it off right to the "Max" line on the stick, as per Jag tech bulletin. I had a delayed engagement problem with my '95 XJRwhen the fluid level was simply in the "acceptable" range on the dipstick.
Old Dec 30, 2008 | 01:36 AM
cool's Avatar
yes there is a drain plug on the torque converter and i strongly suggest just use ATF of Dexron III grade without all those additive. to be safe use good brands and sealed bottles.
Old Jan 18, 2009 | 06:47 PM
ah ha this is true but my poor XJR had a rough life with its past owners. Lucas made her feel a little better, but it's still missing something. My '96 has a magnificent responsive feel even being naturally aspirated.
Old Sep 23, 2010 | 02:06 PM
jonjay1's Avatar
is their any other trans fluid i can use other than dealer fluid for a 1999 xk8
Old Sep 23, 2010 | 04:35 PM
sempire's Avatar
I always use the AMSOIL stuff from GTAsynthetics.com, delivered to my house in 2 days no problem.. I put my car up on jacks and wait for the mail man..
RaceDiagnostics
Apr 4, 2016 04:00 PM
millertic
Sep 30, 2015 08:11 PM
dmatthewman
Sep 30, 2015 10:10 AM
jjmiah217
Sep 28, 2015 09:09 AM
