Trunk will not open
Old 04-24-2018, 04:27 PM
jomo's Avatar
Default Trunk will not open
Hi,
The weather was simply perfect today to fix a few things on my xj6 which went very well. Since one repair involved removing the air bag I decided to disconnect the battery. After all the work was completely I went to reconnect the battery only to find out that I can't open my boot/trunk, even with the key.
So my question is how can I get 12 volts to my car so that I can open up the trunk?
Thanks,
Jomo
Old 04-24-2018, 04:38 PM
Lady Penelope's Avatar
Received 1,383 Likes on 1,087 Posts
Yes , The 3 large single wire terminal post on the rear upper firewall of the engine compartment are the red B + leads from the battery . And them just find a ground for the black jumper cable . It is not recommended to fully jump start the engine this way .
It is important not to get the cables from the donor battery to the jumpered car not crossed . Donor battery B + red lead to one of the 3 large single wire B + terminal post on the helped car .
jomo (04-24-2018)
Old 04-24-2018, 05:17 PM
jomo's Avatar
Originally Posted by Lady Penelope
Yes , The 3 large terminal post on the rear upper firewall of the engine compartment are the B + leads from the battery . And them just find a ground for the jumper cable . It is not recommended to fully jump start the engine this way .
Yep, I got the trunk open. Thanks.
Lady Penelope (04-24-2018)
Old 04-24-2018, 08:36 PM
Received 7,900 Likes on 4,772 Posts
Please learn to use the key occasionally to avoid the lock cylinder seizing.
bob
Don B (04-25-2018)
XJL2011
09-23-2023 09:58 PM
tnt
05-23-2022 07:30 PM
6pac
09-20-2008 06:43 PM
Quick Reply: Trunk will not open
