In an attempt to R and R the steering column motors, I was doing well until I came to removing the steering column lower shroud. The lower of the two screws was not a problem, it's a regular Philips head. The problem was the upper screw nearest the steering wheel. It's the strangest screw head I've ever seen. It's kinda like a wide Philips screw head, but I don't know. The question is what do I use to remove this screw? Would a #3 Philips with a bit of the tip ground off work. What have others who have repaired their columns used? Thanks in advance
