weird ??
Old Sep 5, 2018 | 02:26 PM
mtotrainer's Avatar
Default weird ??
Today my 96 vanden plas 4.0 i6 started acting strange. The engine idle rises and lowers over and over, it only shifts into second gear unless I accelerate hard, the air conditioning suddenly blows warm air unless I accelerate hard and then it blows nice and cold. Also there was blue smoke billowing out the tail pipes once while idling at a trafic light. When i go to pull away from a stop the engine stumbles but then accelerates away fine.Sometimes the idle stays around 1500 while I'm slowing down and I need to make the brakes slow the car instead of engine braking, if I slip into neutral the engine revs quite high.All this on a ten mile ride just today. What's going wrong? I should also mention, I have no trouble lights on the dash.
Old Sep 5, 2018 | 02:31 PM
JagV8's Avatar
Might be an air leak - watch fuel trims to see. Lots of posts about what to do...
Old Sep 5, 2018 | 02:58 PM
Mark Murphy's Avatar
Maybe the throttle body needs cleaning/and or the tps out of range, or as above.
Old Sep 5, 2018 | 05:42 PM
Lady Penelope's Avatar
The engine and seperate transmissiopn ECU yalk to each other yhtpough the transmission body connector .
Has a history of giving eqach other problem as they relate to each other at low RPMs .
nO JACKING NEEDDED Easy try .
Be careful on reoval as to weither it twist off or pops off like a air hose .You might spry with some loosening penatrate beforehand .
Old Sep 5, 2018 | 06:56 PM
mtotrainer's Avatar
Default Body connector
What is the body connector and where is it located on the car?
Old Sep 5, 2018 | 07:00 PM
mtotrainer's Avatar
could you tell me where this body connector is located and also what it is? Thx j
Old Sep 5, 2018 | 07:33 PM
Left side , on the rear pointing aft .
Buut then there are 2 others being the rototyy swith just fwd as the square sheet metal and the one linier sitch on the right side of the shift box from the top side tyhat gets moisture in it .
tHE ROTORY SWITCH HAS A YHIN O - RING SEAL / HARD TO PLACSE BACK IN POSITION .
sEE [AGE 65 ;
http://www.jagrepair.com/images/Auto.../jagxj1996.pdf
Old Sep 6, 2018 | 02:57 AM
SleekJag12's Avatar
If this was a sudden onset of the problems, it could be the Crankshaft Position Sensor (CKPS) failing. That is the item that is most suspect for sudden poor running. It can cause weird behavior without setting any codes. Have you ever replaced it? If not, that would be a good place to start.
Odd things can happen if the Mass Airflow meter (MAF) or the coolant temperature sensor quit. Check the condition of all the connectors first.
Did the car just have any services done? If so you want to look for troubles that could be related to the service, or at least look around in the area of the car that was serviced.
Old Sep 6, 2018 | 05:29 PM
mtotrainer's Avatar
Default Thx
Thanks very much folks. I will get checking all these switches and connectors. Thx again for pointing me in the direction.
Old Sep 6, 2018 | 06:35 PM
Clean the left extrnal aft round connector before a effort on the switches
Old Sep 7, 2018 | 07:41 AM
Ric in RVA's Avatar
If idle issues are a major symptom then a look at and clean of the idle air control valve IACV would seem to be in order. Vacuum leaks are a big suspicion too since a vac leak make the IACV less effective.
Old Sep 13, 2018 | 09:59 AM
mtotrainer's Avatar
Default Confused
i dont understand what you are saying to me. What is this external aft round connector and where is it? Under the hood or on the body or in the trunk? I truely dont know.
Old Sep 13, 2018 | 10:07 AM
On the transmission itself on the left side as the # GH3
Do not twist too hard as I beleive it is a bayonnet connector like a air hose coupler .
Keep asking questions .​​​​​​
This one connector from readings gives people problems down low in the shifting RPMs .
On the later ZF5HP24 transmission on the V8 version X308 it gets contaminated with fluid leaks from above .
Igloo112
Oct 6, 2007 01:30 PM
shaguarBILL80
Jul 28, 2007 03:26 PM
seeyouincourt28
Feb 20, 2007 12:03 PM
