wont turn over
Old Mar 11, 2009 | 11:54 AM
jdbryant's Avatar
Default wont turn over
97 xj6 wont turn over, everthing else works fine. new battery,
any sugestions?
Old Mar 11, 2009 | 12:21 PM
JagtechOhio's Avatar
If this has anything to do with the accident, check the fuel inertia switch. It's in the right front footwell, behind the carpet. Push the button on the top down and see if that gets you anywhere. Check your other post about the body parts, I have what you need.
Old Mar 11, 2009 | 02:27 PM
jdbryant's Avatar
Default inertia switch
I've pulled the trim in the kick panel off but didnt see the switch, an I looking in the right spot? Thanks
Old Mar 11, 2009 | 02:40 PM
Passenger's side front foot well, right front corner, maybe six inches above the floor, you don't have to remove the vinyl side panel to press the button...just pull the carpet back a little. It's a soft round rubber button cover on top of the inertia switch, about 1" in diameter. I just pushed the one on my '97 VDP, so that's where it is.
Old Mar 12, 2009 | 07:56 PM
jag_genius's Avatar
beside the ecm .. closer to the firewall
Old Mar 13, 2009 | 07:03 AM
jdbryant's Avatar
located the button, but still didnt turn over after pushing.???
Old Mar 16, 2009 | 03:38 PM
jdbryant's Avatar
Default wont start
car is at mechanic, they got it to turn over but wont fire. Thanks for your help so far JagTech.
Old Mar 16, 2009 | 06:31 PM
I talked to your guy today, he verified that there was no injector pulse along with no fuel pump feed, so the ECM relay sounds like the next problem...and it's right in the area where the car took the hit. Hoping to hear back when the car is running, call me if you're still hung up.
Old Mar 16, 2009 | 08:40 PM
Nice follow thru Jagtech
JarodL
Mar 7, 2024 01:39 AM
RaceDiagnostics
Jul 7, 2022 06:41 AM
Malihide
Apr 2, 2016 04:05 PM
abonano
25
Sep 25, 2015 10:43 AM
ZJag
Sep 15, 2015 03:39 PM
